cams?
Old Nov 5, 2011 | 05:14 PM
dodgeman1999's Avatar
cams?
going to be changing out my cam and just wanted to see what company to go with thanks for any info
Old Nov 5, 2011 | 07:48 PM
RyeThomas's Avatar
Winner winner chicken dinner!
Do a search you will find many opinions and many arguments.
F-1
Hamilton
Fletcher
Are the big ones.
Old Nov 6, 2011 | 04:46 PM
Bswope's Avatar
Hamilton........ nough said!
Old Nov 6, 2011 | 05:58 PM
carl48's Avatar
you need to fill out your sig and tell us how you use the truck. there are many different grinds for as many different uses and generations.
Old Nov 6, 2011 | 06:00 PM
trksrfun's Avatar
Most will also say to go with a new cam vs a re-grind....
Old Nov 6, 2011 | 08:14 PM
White Ghost's Avatar
I love the big stick I got from Hamilton . I tow heavy loads all the time. It has great top end power when I am not hooked up to my trailer . It is a great all around cam. It is one of their older grinds. Good luck on choosing cam.
Old Nov 7, 2011 | 08:26 AM
AH64ID's Avatar
I have a colt cam and really like it.
There are several common grinds sold by more than one company. The grind you run comes down to the intended use.
Old Nov 7, 2011 | 05:34 PM
thanks guys been looking at hamiltons alot i have an 05 6sp that is undergoing surgery haha it currently has bdtd with crazzy larry stacked with a quad box 100hp sticks 33%over pump dual feed lines bd super b special airdog 165 pump cfm intake horn south bend dual disk with hyd upgrate
going to be doing the cam dual pumps twins studs orings 250-300hp sticks 110lb springs and hd push rods and intercooler now just trying to decide what companies to go with on each parts
Old Nov 7, 2011 | 05:35 PM
shooting to be 900-1000 at the wheel when done on fuel only
Old Nov 7, 2011 | 05:39 PM
twins wise im thinking either bds r1000 kit or ii racing twins bds would probably spool better but dont know if it would have enough top end compared to the ii set
bd uses 64 and 82.2
ii uses 66 and big brother
Old Nov 7, 2011 | 06:33 PM
carl48's Avatar
for what you want the hamilton is best.
Old Nov 7, 2011 | 09:28 PM
Spooler's Avatar
I am testing out a new Hamilton Cam. The 178/208. I will let you know how it does when I get it installed. It is going to be Thanksgiving weekend as long as the weather is good. The truck hangs out the garage...LOL
Old Nov 8, 2011 | 08:45 AM
AH64ID's Avatar
bd uses 64 and 82.2
Talk to Hamilton about some of their new big cams, and talk to Colt. Both of them have some more recent big turbo cams, that may or may not require fly-cut pistons.
coreydr2003
24
Sep 17, 2008 12:17 PM
cquestad
Sep 13, 2004 12:39 PM
ddestruel
13
Aug 17, 2004 03:38 PM
SjLingenfelter
Mar 2, 2003 04:21 AM
