Bushwacker Extend-a-Fender
Old Mar 25, 2009 | 01:11 PM
roadgeneral's Avatar
I just purchased a set of Bushwacker Extend-a-Fender fender flares to protect the sides of my Ram 2500. After putting on a set of 305/55-20s with a positive offset to clear everything, I need to stop the mud and water from coating the sides of the truck.
In the instructions, it states that I first must remove the big "C" Turbo Diesel badge from the front fender. I assume it is glued on, so how do I get in off? Has anyone done that before? And doesn't it leave a mark on the fender?
Old Mar 25, 2009 | 01:44 PM
saddiesel's Avatar
Do a search on debadging for alot of ideas. I used fishing line to remove the badge and then an eraser for the remaining stuff.
Old Mar 25, 2009 | 02:48 PM
GlennRMK's Avatar
^What he said!^
I used fishing line and heated it up with a heat gun. Then used some goo gone and got it off.
Kind of PIA
Old Mar 25, 2009 | 02:57 PM
Megadeth's Avatar
I used fishing line and a hair dryer to saw it off, then bought some 3M adhesive remover and drenched the glue with that and it pretty much slid off.
Old Mar 25, 2009 | 03:09 PM
Thanks for responding! I think I have the idea now.............all good tips!!
Old Mar 25, 2009 | 06:26 PM
cbrahs's Avatar
fishin line and a 3m eraser wheel and a bit of adhesive remover to get the final touches off. works great
Old Mar 25, 2009 | 07:24 PM
xtoyz17's Avatar
Cant start something like this and not post some photos of the wheels and tires!!!
Old Mar 26, 2009 | 08:24 AM
schv's Avatar
Before you start ripping your CUmmins badges off, are you sure you have to? I think that instruction applies to `05 and earlier trucks - on the `06 the badge is not in the way.
Old Mar 26, 2009 | 08:36 AM
DNRCustoms's Avatar
X2 don't think there is a need. My badge is still on and I have the same flares and a 06.
Old Mar 26, 2009 | 08:51 AM
xyzer's Avatar
If you don't fish dental floss works also. Don't get in a hurry! That is if you have to remove it.
Old Mar 26, 2009 | 09:26 AM
alboy's Avatar
I have the Bushwacker flares also plus the 305/55/20 wheels,no need to remove the cummins emblem on a 06.
Old Mar 26, 2009 | 05:27 PM
xtoyz17's Avatar
Wish my previous owner knew that, I want my badges back!
Old Mar 27, 2009 | 09:20 PM
All you guy are right................................as I looked the job over, I could see that the badge was not in the way!! I held the flare up to see the fit and sure enough, the badge clears. THAT'S WHAT I GET FOR READING THE INSTRUCTIONS FIRST!!
chadsdodge
Nov 22, 2008 07:05 PM
Ga_Mike
Jul 30, 2007 01:29 PM
JPR Ram
Jul 21, 2007 05:39 PM
k6jr
15
Jul 27, 2005 10:51 AM
tobyw
Jan 10, 2003 07:15 PM
