Bullydog power pup tuner
Does this void any part of the vehicle warranty, if unplugged does it leave a signature, is it worth the cash, with a 6spd will it smoke out traffic?
can't answer any questions except the smoke one. On the highest setting will will smoke when you put your foot to the floor but clears up pretty quickly. you gotta mash the peddle pretty good for it to smoke tho, its very easy to not make it smoke
Signature? I'm unsure about this. My dealer was fine with it.
Smoke. Put it in a high gear and lug the engine. Step into pedal and watch the smoke fill the air.
alright thanks yall, i want the smoke so it is not a bad thing, and yall think the cost was well worth it? What about milage, I now get about 18-25, will this drop alot, or if I just blow by a few FoRdS from time to time it wiould be just fine?
If you keep the smoke from pouring out, your mileage will go up.
My dealer sold mine to me and watched me program my truck. I have no transmission warranty but everything else is still warrantied.
i think it does leave a signature..."i think" it time / date stamps the last reload of the ECM program.
if the dealer's software is up to date, they can tell what it was,
if their software is too old, they won't know. but this is all hearsay from a buddy who took his truck to 2 places, and one knew it was a "box" on it for mods, and the other dealership was unable to tell what was going on.
if you are talking about the Bullydog Power pup downloader, here
is the "Perf" setting in my automatic.
http://04ctd.zippyvideos.com/
i can't make it smoke in traffic/ when moving, but the strait pipe usually takes of that, let off gas, lug it going by, then stomp it.
not that i don't have a life, or anything.....
thanks for the help, i know that the banks six pack leaves a sig, but was unsure about this, either way if the part breaks with or without mod then it was needing better anyways
Cheers
Bekim
The dealership can tell if they are looking for it. If you just go in for an oil change or ECM flash they are not likely to look for something. However if your go in with a hole burned through #6 piston they might start looking. The key cycles counter is reset by the BDDL, which is a big sign. The maximum values data as well as the freeze frame data is another area they can look.
Beleive me if they want to digg into it. They **** sure can find out if you have run one. I am not sure if your local ******* could find out if you have run one. But I would like to bet weather the factory could if it was sent back.
Let's just say that if your going to bomb, then your taking a risk no matter what! If you throw a rod or burn a piston or lose a lift pump because of a mod, then there's the risk whether it voids the warranty or not these are bad things!!
But the power is sooooo sweet!!!!
Cheers
Bekim
2huntforever
Jul 20, 2005 07:28 PM
jayrods600
Mar 14, 2005 08:22 PM
LinearX
14
Mar 9, 2005 12:39 PM
deezulsmoke
Jan 18, 2005 12:15 AM
