Bully Dog
Bully Dog
I have my buddy's triple dog and he is enjoying my predator, my question is can I put my power puck stacked with the bully dog, i have it on Extreme and its not very inpressive, I want more power... but I dont have a RP guage to monitor this, does anyone know if I will be ok.... or is not recomended to stack these?
Thanks
Kyle
Thanks
Kyle
Thanks
Kyle
Thanks
Kyle
if you have a predator power puck, then the answer is yes.
Basically if you popped your hood to plug-n-play then you can stack a downloader/programmer, but you can't stack 2 downloaders/programmers.
Hopes this helps
ok I will stack these... my buddy has my predator and I now have his POS bully dog, i am trying to get more out of it so the stack will bascially be my puck with the bully dog and i just didnt want to blow an injector tonite because I will have a couple people with me and it no fun when broken!!
The triple dog doesn't raise the pressure on tow or performance, but it does raise rp in the extreme mode. So only run the stack in the lower modes. You should get someone to email you crazy larry or scary larry.
crazy larry or scary larry would be a bit much on the stock G-56, but i will run the performance with the puck untill I get my predator back. once again thanks for all the info!!
As I was told, none of the TD or PMT programs add pressure. I have Scary Larry and Crazy larry and whatever Larrys are out there. To the best of my recollection none raise FP.
I've heard people say scary larry can crack inj. One of the guys at BD told me they didn't raise the peak pressure until the extreme modes when I was stacking with my pmt.
I don't understand why you call the BD a POS and want to stack, but the larrys are to much??? The g56 is fine, but if your pickup likes the crazy or scary larry it should be able to slip the clutch quit nicely.
CLeger67
Apr 7, 2008 08:17 AM
chevkiller
16
Feb 16, 2004 01:14 PM
Push Rod
Feb 8, 2003 07:51 PM
