the bully in bullydog
he guys, have an 06 megacab i bought a few months back. after opening up the intake side i bought a brand new superchips programmer off ebay for a couple hundred bucks. i went to install it and it would not read my truck. called superchips and they said to update the programmer. date of manufacture showed 7-31-09 but i did it anyway. after a failed second time i called superchips back. they read the info the tuner was recieving and stated it appeared the previous owner had a shop install one of bullydogs "try before you buy" programs and it left a footprint in the "skim key" area of the PCM. said the only way to clear this was to have the dealer reflash the PCM to the tune of $90 bucks. emailed bullydog and they gave me some b.s. the first time, havent heard back the second time, but it appears they dont care.
is their anyway to get ride of this leftover junk bullydog left in my truck so i can upload the superchips. just to clarify the bullydog tune is long gone, the truck is running on the stock tune. sorry for the long post. any help would be great....
I like that, "bullydog ghost" haunting the truck.
Unfortunately, that is exactly what it is and the only way to get rid of it reprogram the ECU. The BDTD had a nasty habit of leaving remnants of itself even after it expired, chiefly it wrote a Brazilian VIN into the ECU and you were stuck until it was reflashed back to one the programmers recognize.
Ask me how I know this.
This is NOT a knock on the BDTD products, just a comment on what could be considered less than ethical marketing tactics or just plain sloppy programming. You decide.
Our crewtruck Duramax was put back to stock but still has the same power as if it was still loaded with the extreme tune. Kinda makes me think trying a Bully Dog is not a good idea!! We are using it in a Dodge so I know it was put back to stock. Nice to have tons of power in the Duramax though!!
I just went through a fiasco 2 weeks ago when I dyno tested CL/SL aginst Smarty TNT/R and when I went to unload the BD it wiped out the callibration codes for my ABS system.
2 weeks, 4 phone calls, and 2 emails to tech support, still no answer.
Thanks god i found a dealer that could help me out.
no 6 oh no, i side with you, less than ethical marketing tactics or just plain sloppy programming. thinking the latter since i hear this problem has been dealt with on the newer tunes. either way bullydog has not responded and i doubt i will get anything outta them.
wyodsl, i will keep your pm in mind if i cant get anything going with them, thx for the offer and the info!
just a quick update. took the truck to the dealer, had to pay 98 bucks to get it re-flashed. came home and the superchips worked perfect. called bullydog before going, no kiddin they told me to tell the dealer the truck has a rough idle and hope they do a reflash under the motors 100k warranty! yeah, didnt try that, just paid the money. thanks for nothing bullydog....
I would type up an official looking bill from yourself, Itemize time for phone calls, to bdog and s chips, dealer time, travel time, and the cost of the reflash and send it to bully dog. I would also go as far as including the bill in a thread here and a few other sites, and include a link to the threads so bdog can follow up and came clean.
yeah i am dissapointed in their service too. talked to two different techs with bullydog, and they contradicted eachother. after the 2nd tech advised me to try and lie to the dealer i knew their business practices werent the best.
another question, when i loaded the superchips it said it couldnt modify tire size because of no ABS module. like 2007 5.9 above, you think the BD messed up my ABS calibration? cuz i know the truck has ABS.... or at least is supposed to, and one of the reasons i bought the superchips was to correct the speedo, more importantly the odometer. im gunna call the dealer and ask, cuz after the re-flash all that should have been corrected, right?
LilBigd02
17
Feb 28, 2010 09:22 AM
CLeger67
Apr 7, 2008 08:17 AM
