built transmissions and codes
Old May 27, 2007 | 10:07 PM
RNX CTD's Avatar
I'am bought to drop some bones to get the ol 48re upgraded going to talk to dave goerend and get every thing my $4500 can get. so are all u guys with updated transmissions running around with the check engine light on and transmission codes?
Old May 27, 2007 | 10:10 PM
jrussell's Avatar
No codes whatsoever.
You will love your tranny once Dave gets a hold of it!
Old May 28, 2007 | 01:33 AM
firemansdiesel's Avatar
I had mine done a couple of months ago. I got a BD TC and Vb done. After a couple of days I got a P1740 code and engine light. I called my diesel perfprmance shop that installed it and BD Performance. They said it is normal for 05 especially to get this code. It has to do w/ the TC locking up at a different rpm than the stocker. So the truck computer thinks the tc is slipping. Truck and tranny run fine. I also heard it from other people on another forum w/ the same situation as me. Since you have a 07. I don't know if they are prone to throw the code or not.
Someone told me Dave had something in the works to get the code not to throw. Never bothered to call and ask.
Old May 28, 2007 | 06:09 PM
RNX CTD's Avatar
I have read many post here saying the updated trannys such as Tc and VB makes the turbo bark. I am not going to add a whole lot of power i tow a bit and just want the best towing experience. probley going to sell the quad race and buy the towing box quads got with pressure only and a smarty or diablo with commander. going to try do get the lift pump same time, then thats it untill christmas and get a nice towing turbo. then put money back for the warranty fund. will i have any real issues with turbo bark?
congratz to Rampage Jackson !!!
Old May 28, 2007 | 06:16 PM
jrussell's Avatar
The barking from the tighter TC isn't as much of a problem as I had expected. You quickly learn how to avoid it. For me it has only happened when I'm into the throttle just enough and then let off just enough right before it shifts. It's a relatively mild bark too...not like letting off all the way while under 40psi of boost or anything.
Old May 28, 2007 | 09:16 PM
03qclb5spd's Avatar
My buddy just had his trans built up a bit with some goerend stuff. He is very happy with it so far.
zachv
14
May 17, 2014 02:12 AM
jesussaves
Dec 30, 2009 06:35 PM
robert97dodge
Jun 25, 2009 06:24 AM
rowilson
Aug 23, 2006 03:31 PM
stevenknapp
27
Jul 10, 2004 01:11 AM
