Bottom line on Modded CP3
Old Dec 15, 2006 | 10:46 AM
Don M's Avatar
DTR Advertiser
John can take the pump off, modify it and re-install.
It does not happen "right now" though. It takes some time to get everything lined out. Most trucks end up being there days, not hours.
John has the modded pumps figured out better than anyone now.
Don~
Old Dec 15, 2006 | 10:50 AM
Sloverado's Avatar
Don~
I will second that!!
Old Dec 15, 2006 | 11:40 AM
Dan Marino's Avatar
Don~
So what happens to a West Virginia boy? Take it off and send it?
Old Dec 15, 2006 | 12:37 PM
Sloverado's Avatar
Yes that would be the best way.
Old Dec 15, 2006 | 12:54 PM
Dan Marino's Avatar
Any kind of warranty with the work? You say you paid round 1300 - did that include labor for taking it off and putting back on?
Old Dec 15, 2006 | 12:56 PM
Sloverado's Avatar
I don't think so. I think that was somewhere in the price without labor.
Old Dec 15, 2006 | 01:08 PM
Dan Marino's Avatar
So, does anyone have any idea of time and the amount of effort it takes to get the CP3 off and on?
Old Dec 15, 2006 | 01:13 PM
masonic-dodge's Avatar
Changing a CP3 is alot easier then a P-7100. It will take less then 1 hour to do the swap After you have done it before it will only take 1/2 hour.
You will need the tool to pull the gear and also holds it in place when the pump is out.
CRIS
Old Dec 15, 2006 | 01:21 PM
Dan Marino's Avatar
CRIS
Masonic - you have stage 2 / Sloverado has stage 3 / what is the difference?
Do you like what it has done for your truck?
Old Dec 15, 2006 | 01:23 PM
Dan Marino's Avatar
How is driveability affected with this mod??? Can you still take a 1700 mile round trip interstate trip with no ill effects????
Old Dec 15, 2006 | 01:25 PM
The stage 2 I have keeps the rail full of fuel, but it is noisey. All the pumps that have been modded are louder then a stock pump.
I don't know what is different between a 2 and 3, sorry.
CRIS
Old Dec 15, 2006 | 01:28 PM
Dan Marino's Avatar
CRIS
OK, I gotta run for the evening guys -Christmas shopping for my kids. Keep the info comming. I appreciate the time you guys have taken to help out.
Ill check back late.
Old Dec 15, 2006 | 01:39 PM
PourinDiesel's Avatar
Changing pumps is pretty simple. Although it does take a little muscle to pull the pump and push it back in.
Very straight forward. Very doable even for the novice with the proper equipment.
Old Dec 15, 2006 | 02:46 PM
metal_miner's Avatar
I bought a spare CP3 from a wrecked truck and then had it checked out for flow specs, any internal damage, and then modded. It was a good thing I did this because my modded pump went TU. So I was able to slap my stock CP3 back in and continue driving my truck while the vendors took care of the modded pump. Keep in mind this was when the modded CP3 first came to market so it should be safe to say that all the bugs have been worked out.
The part that usually goes TU in the CP3 is the FCA. Modded or stock FCA have tight tolerances so any little contamination or burrs will throw off the operation of the machined plunger in the FCA that controls the fuel rail pressure, especially off-idle, since the plunger can "hang up" and delay fuel rail pressure buildup. When this happens, we get erratic idle and late injection timing = white smoke.
The rest of the CP3 is a fairly robust unit. However, if any machine work is done to it, then cleanliness is godliness.
Old Dec 15, 2006 | 03:38 PM
PanteraGSTK's Avatar
Hey Dan, do they make a locker for the 11.5" rear yet Sorry, I couldn't help it. This is the first time I've seen YOU ask a question.
As far as your question goes. Do you mind lag? Cause to get to 650 I'd think there would be lots of it(with a single). Of course the new pump and injectors can make up for it I guess. Good luck.
