Boost #'s with AFE
Old Jul 7, 2005 | 09:39 PM
snow104's Avatar
42-45 seems a bit high for a stock fueled truck and the plastic inner cooler.
I havent noticed any diff with my 05 but I have boost limited to35 onmy eadge box
Old Jul 7, 2005 | 09:51 PM
nickleinonen's Avatar
04.5's got the aluminum tanked charge air coolers on them.... they don't go pop like the plastic ones do
Old Jul 7, 2005 | 10:14 PM
snow104's Avatar
6000 mi. seems to work great.
Power is smooth.
I like the guages and on the fly program changes.
Oh and the safety features.
I would do it again
Old Jul 7, 2005 | 10:42 PM
RamWheelsBy4's Avatar
Pull U 2
I have had Quad XZillaraider Race, standard Juice/Attitude and currently have HOT Juice/Attitude. The XZillaraider Race box worked great without issues or problems. The Juice boxes have also worked great. I believe that the Juice is more responsive on the low end. I wanted the HOT juice and the Attitude options is one reason I chose to stay with the HOT Juice.
Both boxes on the 100hp setting produced about the same HP on the dyno. The Juice seemed to climb into the peak hp and torque earlier. That is IMO.
XZillaraider Race on 100hp and 130hp would produce 44psi boost. The Juice on 100hp will produce about 41psi. My truck stock would spike to 32-33psi and sustain 28-30psi on WOT.
I switched from standard AFE filter to Pro-Guard 7. I could definitely tell there was less air. The Pro-Guard 7 is very restrictive, that is why it has such a good filtering rep. You might to try a standard filter, it has an additional filtering surface that helps it provide more air. I have each so I can switch for track and make it easier to clean and dry.
sinawalli
Mar 5, 2011 08:43 PM
surfram
Jul 17, 2006 02:06 PM
diesel_work
Oct 8, 2005 12:25 PM
sawboywv1
Jul 15, 2004 10:31 AM
