Boost Problem Guys and Gals
Old Oct 27, 2008 | 06:18 PM
DENVERDODGE04's Avatar
Thumbs down Boost Problem Guys and Gals
Alright so maybe you guys can tell me what is going on with my truck, so for a heads up i'm using a banks six gun and i hate it, i think i'm going to tst powermax, but anyway i put a boost elbow on 2 days ago because it would never spool above 25 psi (ever) so i fired it up and it gave me 27 psi and never went back to it again i can't get it over 25 psi, it is a stock turbo so figured its good to at least 36-40 psi, if somone has an idea or suggestion other then ditch the banks i already know that and i'm trying. Thanks alot, DENVERDODGE
Early 04 dodge 2500
Old Oct 27, 2008 | 07:10 PM
Silverram03's Avatar
You may be hitting the roof as far as fueling goes, you may need to upgrade your fuel system since fuel makes boost. You may also have a boost leak somewhere. My 03 will hit 28 lbs. with my SMARTY on #7 with a stock turbo with factory boost elbow.
Greg
Old Oct 27, 2008 | 07:16 PM
Totallyrad's Avatar
Start simple, check the clamps on the boots, then dump the Banks.
Old Oct 27, 2008 | 07:18 PM
i figured my fass 150 would take care of that though....
Old Oct 27, 2008 | 07:21 PM
05ChainSmoker's Avatar
i used to have the banks on my truck and it would hit 37 with just the six gun it sounds like you might have a boost leak some where
Old Oct 27, 2008 | 07:25 PM
megacabdad's Avatar
Where are you reading this boost at?
You got analog gauges or the PDA?
25-32#'s are normal for stock to mild tuners like the one you got...
Old Oct 27, 2008 | 07:27 PM
does the ecm take over boost somehow, by defueling at a certain psi?
rip 112's Avatar
Check for boost leaks and know that the Banks isn't a heavy fueler. I couldn't get much boost out of it either. The Smarty however got me 35psi max on the stocker. You do not want to exceed 35psi, I would aim for 30psi and be happy.
Old Oct 27, 2008 | 07:31 PM
well if 30 is safe for the stocker i don't even no why i'm bothering, looks i need to get rid of the banks and look for a little bigger turbo.
Old Oct 27, 2008 | 07:34 PM
I'm using the pda as gauges, and i'v heard you could easily get a stock turbo into the high 30's low 40's safely, not true though?
Old Oct 27, 2008 | 07:37 PM
megacabdad's Avatar
Yo DENVERDODGE!
You now what response is coming next?...
Get a freakin' Smarty PoD...
With your FASS and tranny, and the infinite adjustability...you will need many more mods before you outgrow it
Old Oct 27, 2008 | 07:42 PM
Yo DENVERDODGE!
I figured you guys would say that. Thats why i made a note about it above, i was leaning more towards tst powermax, pro/cons over smarty?
Old Oct 27, 2008 | 07:47 PM
87BRGN's Avatar
The PDA is reading the MAP for pressure reference... if there is any sort of fooling or remapping involved with the Banks your boost# probably aren't accurate. The stock turbo is blowing really hot after 30-32 psi. 04.5 and newer trucks are in the high 30s safely.
Old Oct 27, 2008 | 07:48 PM
megacabdad's Avatar
You guys didn't say it...I said it
I'm pretty sure they don't compare...
You can stack the two...but one vs. the other...don't think their is a comparison...
Old Oct 27, 2008 | 07:50 PM
87BRGN's Avatar
Heck you've already got the trans and fass. get'em both.
