Boost installation---where does it connect
Old Aug 17, 2004 | 09:55 AM
MPowell800's Avatar
I struggled with this last night for entirely too long.....
I can not seem to find where to insert the 1/8 npt fitting for the boost gauge.
All the information that I can find is on 2002 & newer stating that there is a 3/4" plug with a 3/8" square in the middle that you can remove with a socket wrench. This is indeed true on a 2002.
Now, with that said -- where in the world do you put it on a 2004. This is not the 600hp motor either.
Any help would be greatly appreciated.
Mike
Old Aug 17, 2004 | 10:51 AM
Tom488's Avatar
Remove the intercooler boot from the intake horn, then drill and tap the base of the intake for 1/8NPT. Clean out any shavings, re-attach the boot, and install your fitting.
Old Aug 17, 2004 | 11:03 AM
nickleinonen's Avatar
Re: Boost installation---where does it connect
Mike
that plug doesn't exist on the 3rd gen trucks... if you want something real easy, go to piersdiesel.com and get their # and order a boost bolt [they have it on sale right now in their august deals for $10]
or remove the intake horn, drill & tap it, and reinstall it...
Old Aug 17, 2004 | 12:29 PM
vernl's Avatar
I tapped mine in with a tee and some short pieces of hose right at the wastegate actuator worked perfect for 14 months so far
Old Aug 17, 2004 | 05:26 PM
JThiessen's Avatar
If you dont want to wait for someone to ship a boost bolt to you, try calling around to some of your local performance diesel/off road shops (if you have any around you). The boost bolt is a good way to go because its giving you the actual pressure inside the motor. I was headed down the path of using the tee fitting like VERNL suggested, but i couldnt get the right size fittings locally without ordering them.
Old Aug 18, 2004 | 09:45 AM
MPowell800's Avatar
Thanks to everyone--I went with Tom488's advice and tapped the intake horn.
It wasn't bad--it took me 30minutes to do. I have the patience of a 3year old and couldn't wait 2-3 more days to get everything hooked up and done.
Thanks for all your help.
Mike
Old Aug 18, 2004 | 07:09 PM
Mark Thomas's Avatar
I held a shop vac up to the air horn when drilling, not wise to chance a chip going into the motor
barngal6
Jul 8, 2009 05:40 PM
MTGunNut
27
Jan 6, 2007 01:11 PM
Gordonville
Jun 27, 2003 08:25 AM
Apr 10, 2003 11:01 PM
