Which Boost Gauge?
Old Dec 23, 2005 | 01:11 PM
tonyiii1's Avatar
Which Boost Gauge?
I am going to order the Isspro Gauge set and wanted to know if should get the 30lb or 60lb boost gauge. Currently just have basic mods and Edge EZ but may go bigger turbo and injectors in the future. Would this take me beyond 30lbs boost?
Also, is the changing out of the stock transmission pan a must for trans. gauge? I know you can hook it up with stock and it is not a true reading. For the co$t difference, is this a huge deal. I pull a 26ft trailer with ~10-foot pullout and 2-3 dirt bikes (usually this is max weight).
Thanks
Old Dec 23, 2005 | 01:23 PM
PanteraGSTK's Avatar
My roommate has an 05' CTD and a Juce/Atitude from Edge and on level 5 he has seen up to 36# so I'd say go with the 60# guage especially if you are planning on getting a bigger turbo.
Old Dec 23, 2005 | 03:41 PM
Mark Craig's Avatar
tonyiii1,
You need the 60 PSI on any 2003+ and lots of the older trucks if they are modded much etc. If I remember correctly the 2003+ have a prot on the side of the trans case where you can thread in the sender??? If you need some Isspro's give us a call we have them and all the mounts too as well as isolators, wiring harness etc.
Mark @ DPPI
Bradleysram
19
May 12, 2009 08:36 AM
Dave88LX
Sep 12, 2005 12:24 PM
I PASS GAS
Apr 20, 2005 10:12 PM
berner
Nov 8, 2002 06:39 AM
