Boost fooling question?????
I was wondering if I can use the boost fooler from Quadzilla and also run the Quad at the same time??...Can you plug the 2 together??...I found out that the Quad dosent run boost fooling if the power level is off and sometime I like to just run the truck stock.......what would yall suggest????
I just run the boost fooler....and yes you can run both. I have the fooler plugged into the sensor first. My old xzillarder does not seem to boost fool like its supposed to, but with the separate fooler it's golden!
There is no reason that when you have the quad turned off you shouldnt be able to benifit from it. All it does is clamps the voltage coming out of the map sensor so the computer doesnt see the actual boost the engine is producing. We do the same thing with the one we make.
Hook the Quad to the MAP and the fooler to the Quad and you should be good. The only possble problem could be double fooling when the Quad is on might cause the ECU to think there is a problem. Try it and see what happens.
berettaman
Jul 27, 2010 12:41 PM
goose2w1
Jul 23, 2008 10:49 PM
bziggy
May 14, 2008 06:53 PM
vwjunkie53
19
Nov 9, 2007 02:27 PM
