blown headgasket????
Old Nov 3, 2006 | 12:11 PM
hottapper1's Avatar
Exclamation blown headgasket????
I have been loosing coolant for the past month,and to day iwent to check the coolant and i saw some oil residue in the coolent.so do yall think i blew my headgaskets. the truck runs fine but every once in a while the truck will get hot but it cools off real quick.
Old Nov 3, 2006 | 12:21 PM
lmills's Avatar
if you have oil in the coolant, it sure sounds like a headgasket. How did you take it out so fast.
Old Nov 3, 2006 | 12:23 PM
maddog madden's Avatar
yup sounds like it, when i blew mine it ran fine untill it got over 40psi boost, but under that it you would never know. I would have it checked out for sure.
Old Nov 3, 2006 | 12:25 PM
hottapper1's Avatar
I have know idea how i took it out that fast.Should i take it to the dealer or have a diesel shop fix it.
Old Nov 3, 2006 | 12:30 PM
Luken's Avatar
Is your dealer mod friendly?
Old Nov 3, 2006 | 12:31 PM
lmills's Avatar
Are you going to try to sneak it in under warranty? If not, look for a shop in your area that can do it. Where are you located?
Old Nov 3, 2006 | 12:46 PM
hottapper1's Avatar
south texas i might try to get jeff prince to do it.
Old Nov 3, 2006 | 01:17 PM
subspd's Avatar
Let me know where you take it becuase I am also in South Texas and might need work done someday. I am always looking for a good wrench in the area.
Old Nov 3, 2006 | 01:27 PM
cquestad's Avatar
If he has not been pushing 50+ psi...or using drugs, I say it is a Warranty issue! TST or not. Pull it and go get it fixed by a "good" dealer.
Old Nov 3, 2006 | 01:47 PM
Luken's Avatar
I agree... tst or not it shouldn't have blown the HG.
Old Nov 3, 2006 | 05:09 PM
hottapper1's Avatar
well i have been boosting 51psi with just the tst box.I am scared to take it to the dealer they will screw it up.what headstuds is everybody useing arp.and do i need to oring the head or will headstuds do.thanks for the replies everybody.
Old Nov 3, 2006 | 06:04 PM
lmills's Avatar
Headstuds and a stock gasket will hold most anything you can throw at it. The key is to do a very thorough job when you do it. I am avoiding O-ringing as long as possible
Old Nov 3, 2006 | 06:24 PM
hottapper1's Avatar
should i take the head to the machine shop and have them check it ,or just slap
a new gasket in and studs and go to town
Old Nov 3, 2006 | 06:25 PM
lmills's Avatar
the block and head must be flat as possible or it will not seal
Old Nov 4, 2006 | 12:44 AM
abc4yew's Avatar
Hottapper1, Welcome to the gettin blown (headgasket) club!!!! Have who ever does the headgasket to check the flatness of the head and block deck. My block was off quite a bit around cylinders 5 and 6 where the head gasket usually fails on these. Hours and Hours of sanding and polishing. The head was machined 3 Thou and it was perrrrrfect. Get the thicker gasket for greater than normal protrusion and get some headstuds....A1's from Haisley's or ARP's from anyone. Use ARP lube and go to 122ft-lbs. Of course your valves will all have to be relashed....51psi without studs on the intake...Cylinder or Drive pressure with 12 degrees timing at WOT... 60 to 65psi....what was the TST timing set at ....12 or 18 degrees.... Atta Boy, Good luck. ks
