block heater
block heater
I have a question for you all about block heaters. My 93 Dodge had a block heater that would warm the coolant up to 140 and instantly blow hot air to defrost and heat up the cab. My 03 seems like half the time it does not even work, let alone warm up enough to notice. Is there a different pn for a higher output heater? If not I was thinking of plumbing in a tank heater like we used to do at the Pete dealership I worked at. I want warmth!
In have a 06, dont know about the power but i can tell a huge diff when i plug it in. when mine isnt plugged in it almost sounds like the battery is almost to weak to start but plugged in it fires up, but its also -6 here the warmer it is the less you can probly tell the diff
Guest
Posts: n/a
I have my 03 set up on a timer. It comes on about 3 hrs before I'm ready to leave in the AM. Temp gage is just off the 100* mark. I'll fire it up and let it run for about 10 minutes. I'll have some heat by the time I leave the driveway. Full temp in about 3 or 4 miles. I also did the cardboard with a 5" square cutout trick in front of the radiator.
I think the block heaters are 675-750 watts. My old block heater in my 95 Ford was 1000-1200 watts, and man did that sucker eat energy. First month after leaving it plugged in in Alaska I learned about this thing called a Timer after it doubled my energy bill....
I keep mine on a timer for about 2 1/2 to 3 hours before I leave for work. The coolant temperature reads 90* and I never let it set there running for more then 20-30 seconds, (wast of #2). It will start blowing luke warm air in 5 minutes maybe, once I start driving. If I forget to plug her in, the coolant temperature will be about 30*.
You can buy a smarty that has the 3 cyl warm feature.
If I don't put something in front of the radiator, when it is 0 or below, as -6 today, it won't blow warm air for about 10 miles and then it is lukewarm. I had my 92 on a timer for about three hours before I went to work and it was cooking! If I can get a part # of 1k to 1200 watt heater I will install.
rjm022
Dec 11, 2019 09:17 PM
SpeedyWS6
15
Feb 2, 2011 07:22 PM
supersonictoys
Nov 8, 2008 09:17 PM
modiesel
Mar 7, 2008 10:44 AM
