Bilstein question
Bilstein question
I am running Bilstein 5100's schocks on my truck. The front right has been chewing up top bushings for some reason. What is the allen head bolt on top of the shock? What exactly does it do? Any suggestions what the heck is going on with me chewing up bushings?
that allen head is just to hold the shock shaft in place so when you are tightening the nut, the shaft don't spin.
I am with moorepower, sounds like the shocks are too short pullin the busing thru
When I replace the bushing I always use an allen wrench to make sure it is not spinning. Everything is good and tight. I bought the truck with the lift already on it. Are the 5100's the correct shocks for a 4 inch lift from Superlift. When yo usay "topping out" do you mean that they are the incorrect shock? What shock would be the right one?
jack it up and place stands under the frame, so the axle will hang. Now take the bottom shock bolts out and see if you can pull the shocks down further. If you can't, the shocks are too short.
Not trying to hijack the thread but what is the difference between the yellow and blue Bilstein and black and silver bilstein? I know the black and silver are for a 0-2" lift, but are they better than the yellow and blue. I was looking at Geno's Garage and seen the two different types. Time for shocks and I would like to go with the Bilstein shocks but not sure which one I should go with.
I think the yellow and blue are for 2wd and the silver and black are for 4wd? Or maybe the yellow and blue are for trucks that don't have any kind of a lift and the silver and black are good for a 2" lift.
Jay
Jay
I don't think you can get 5100's for a 2wd, I don't know what you have.
Maybe this will help:
http://www.bilsteinus.com/305bilstei...ationguide.pdf
DeathCougar
Mar 27, 2014 10:28 AM
deezulsmoke
Jun 11, 2005 01:52 AM
coobie
Apr 1, 2005 07:57 PM
Commatoze
Nov 24, 2003 05:34 PM
