bilstein help!
Old Nov 20, 2005 | 01:31 PM
marc03's Avatar
bilstein help!
Went to install my bilstein rear shocks. the writing is upside down. Do they go with the boots down or in the regular direction?
Old Nov 20, 2005 | 02:47 PM
CrashCade's Avatar
Personal preference. I would mount them so that the shaft is pointed down. with the cylinder on top!
Old Nov 20, 2005 | 09:21 PM
DR3500's Avatar
They have to be mounted with the shaft up or they won't work.
Old Nov 20, 2005 | 09:41 PM
OOPS's Avatar
Most shocks are designed to be installed "can down". If you do not know which way they go I would contact Bilstein. If you do not mount them the right way the damping will not be right.
Old Nov 20, 2005 | 10:31 PM
THURENfab.'s Avatar
uhhhhh., NO
Bilstien's are one of the few shocks that CAN be mounted with the shaft down, which I prefer, but be sure to keep the shaft clean... Any TRUE "mono-tube" shock is like this...
edit: Thought I might add....
This also means any low quality shock HAS TO have the shaft be up... These shocks would be almost every shock out there commonly availible(rancho5000-9000, monroe, gabriel, factory, etc)
KYB "gas-a-just" shocks and Bilstiens are the two common high quality shocks which are good mono-tube...
Don Thuren
jcw74801
Apr 28, 2009 08:29 PM
KillerBee
Nov 7, 2008 07:20 AM
snowmanx
17
Jul 11, 2007 02:04 PM
broncobilly
Aug 15, 2006 12:08 AM
HOHN
Nov 14, 2003 06:04 PM
