Biggest Dually tire w/o spacers
Old Sep 17, 2009 | 09:51 AM
Ernst223's Avatar
Cool Biggest Dually tire w/o spacers
Hey guys just wondering if anyone has had any luck finding a taller dually m/t tire to run on the stock 17" wheels w/o spacers?
Old Sep 17, 2009 | 09:56 AM
Ernst223's Avatar
I am currently running cooper stt in 265/70/17 and love them but about time for a new set and would like to go taller.
Old Sep 17, 2009 | 11:03 AM
homewrecker's Avatar
A 285/70 is taller but depending on which brand name they may touch.I have Nitto 285's and they touched with a 1/4" spacer.Had to go to a bolt on 2" spacer.My friend is running 285 Firestones and they have about a 1/2" gap when using a 1/4" spacer.Ideally a 255/80/17 would be perfect but only Bfg list them and its still not yet available.
Old Sep 17, 2009 | 08:41 PM
Ernst223's Avatar
Thanks for the info, does anyone else have any bigger tires on your daully?
Old Sep 18, 2009 | 06:30 AM
There are lots of guys running bigger.All the way to 35's.There just isn't any options for taller but skinny.I ran the Cooper st's in 265's like you and loved them but they just don't fill up the fender wells enough.Probably why your looking for a taller tire? Is there a reason you don't want to go to a bolt on spacer?
Old Sep 18, 2009 | 07:46 AM
Ernst223's Avatar
The only reason I dont want to go to a bolt on spacer is that i pull alot of weight quite often, between 20,000-30,000lbs and just worried about a spacer holding up to that. Just personal piece of mind.
Old Sep 18, 2009 | 09:18 AM
Theres a member on here that tows heavy with his.I think his name is Topper.Might want to send him a pm.I haven't towed anywhere near that weight to give you an answer on mine. I bought mine from Arrowcraft.They are steel and very well made.They use 5/8" lugs instead of the stock 9/16" for mounting the outer wheel.I didn't trust the aluminum ones for the same reason as you.
Old Sep 18, 2009 | 08:29 PM
Fisherguy's Avatar
Someone PM'd me they were running 35" Vortracs like mine on his dually, but I musta deleted that pm, sorry...
Old Sep 18, 2009 | 08:38 PM
larrybartlett's Avatar
be careful pulling, I had a firend his tires didn't touch empty but with 15,000 lbs on they did and blew out, heck of a wreck
Old Sep 19, 2009 | 12:36 AM
Jordan5687's Avatar
I'm runnin 285/70/17 nitto all terrain....no spacers have enough gap that even a 30k# load doesn't make them touch. I know you said taller. I'm not sure on that.
Old Sep 19, 2009 | 10:26 AM
Ernst223's Avatar
Jordan do you have any pics of your dually with the 285's on it?
Old Sep 20, 2009 | 09:17 AM
Topper's Avatar
Here are some pics of my 06 with 2" spacers. I tow alot and pretty heavy(10-20 K. I also carry ALOTof weight (5-6k at times more) in the truck and love the way the truck handles with and without weight. I had the same spacers on my 03 which I put about 90,000 miles on them when they were on the 03 and now I have 95,000 on my 06 and the spacers are holding up well. I have had these spacers so long I forgot who made them but I bought them from 4 Sight (518)736-2030 ask for Ivan and tell him your asking about the spacers that Randy Christman uses.
Take care,
Topper
Old Sep 20, 2009 | 09:43 AM
Ernst223's Avatar
what size tires are you running topper?
Old Sep 20, 2009 | 11:09 AM
Topper's Avatar
35x12.50x17 Pro comps at's
Old Sep 20, 2009 | 11:34 AM
rip 112's Avatar
Nice looking truck Topper!!! Are you gonna black it out more or keep it as is? Like that RBP grill.
