Best replacement brake pads?
Old Feb 26, 2009 | 08:55 PM
oldblu's Avatar
Just wondering what everyone has went with or recommends for replacement brakes. What brand of pads and rotors or just turn the factory rotors ? Needing to do some upgrades when i get home this weekend. thanks
Old Feb 26, 2009 | 10:36 PM
jlibert's Avatar
I have almost 160k on a stock set of pads with plenty of material left. I'd say the stockers are pretty good.
Old Feb 27, 2009 | 06:49 AM
stroker101's Avatar
X2 on "OEM"
Old Feb 27, 2009 | 07:16 AM
rogers259's Avatar
x3 on "OEM" pads. Currently have 115k on the stock pads and the only reason I'm replacing them this next weekend is because I'll be towing a bunch this spring and don't want to mess with it 20k+ from now.
Old Feb 27, 2009 | 08:12 AM
WhozNxtLS1's Avatar
x3 on OEM I replaced mine with 75k miles, and mine have to stop 37" tires and a 6inch lift. Still had another 20k in them when replaced.
Old Feb 27, 2009 | 08:24 AM
Pooter's Avatar
I guess im an oddball, I went with Wagners from Napa, had great luck so far.
I didnt even turn them(or scuff up the rotors like I should have) but so far theyre working great. Good braking and quiet.
Old Feb 27, 2009 | 08:26 AM
mattk50's Avatar
I replaced my factory fronts at around 100,000 miles and replaced them with the same factory pads. That was wit a lot of towing as well.I didn't need to turn the rotors either.
Old Feb 27, 2009 | 08:32 AM
truckbouy2's Avatar
From: Frozen Northern Minnesota, Darn Close To Where Perma-Frost Begins...
OEM Premium Line....Yes
OEM Value Line....No No No No No...Lot of sqeeking.
Old Feb 27, 2009 | 09:19 AM
cquestad's Avatar
OEM Original or Premium line are the best. Do not get the value line or any others...
Old Feb 27, 2009 | 08:13 PM
lniemeyer2's Avatar
What's a set of OEM originals running these days?
Old Feb 27, 2009 | 08:22 PM
quadman20's Avatar
We must drive harder here in AZ cause no way we can get 100k on our pads. Just hitting 40k and it time.
Old Feb 28, 2009 | 06:41 PM
Pull Ya's Avatar
I bought some value line. What a mistake!!!!!!! I've never seen so much brake dust--ever. I would strongly recommend NOT buying the value line.
Jay
Old Feb 28, 2009 | 08:11 PM
nrussell's Avatar
same here, I can only get about 40k out of mine too. I tow every day though.
Old Feb 28, 2009 | 10:57 PM
lniemeyer2's Avatar
Probably just the heat down there melting the pads off your rig!
Old Feb 28, 2009 | 11:29 PM
Big Horn 06's Avatar
I'm guilty. Value Line here. squeeeeeeeaaaakkkk and dusty. Don't ask why I replaced them. Major moment on both our parts.............
