Best dyno
Old Oct 6, 2007 | 05:13 PM
bluechrome's Avatar
Best dyno
Well today was a great day for me at the dyno. My numbers Were 505.2 hp and 1008.7 ft-lbs. I wanted to hit 500 so bad and it worked. I did this with a stock lp-cp3 and stix. Not bad for a mustang dyno. I did this with the power puck on 60 and standard smarty on #9 That was a 50hp gain over 4.4only. I made power to 3200 but then it dropped off. Bob anMarco need to find out what is wrong with this speed limiter software, It keeps thowing a code. But other than that It was awesome. This power puck stack really works so try it. Boost was 48psi and dyno load was 30,000 lbs of resistence
Old Oct 7, 2007 | 05:23 PM
wap's Avatar
wap
Nice numbers especially for a stock LP.
What code are you gettin?
Old Oct 7, 2007 | 05:29 PM
SlowSixSpeed's Avatar
Great #'s man.
Did you make any runs w/ the Smarty on a lower setting.
Since you still have stock LP and CP3 you may be starving it of fuel on the higher settings.
Ive noticed my truck pulls harder on the lower settings and then add pressure.
It must be nice to hit 500hp and I think that you might be able to get more with more dyno time and settings.
There's a few members that are around 600hp with similar mods.
Its worth a shot.
SSS
Old Oct 7, 2007 | 06:28 PM
bluechrome's Avatar
Thanx guys, The code I'm getting is Map sensor voltage to high. I know I need more fuel for sure I did try smarty 4.4 #7 and it did 461, but That was with out the puck. Another interesting thing I found out is that my friend with a similar set up Made no extra power with an mp-8 on or off But rail pressure still goes to 26,000psi I was very pleased with everything expect the smoke
Old Oct 7, 2007 | 06:33 PM
53 willys's Avatar
great numbers dude
do you think the puck might be throwing the code??? it hooks to the MAP right?
Old Oct 7, 2007 | 06:46 PM
bluechrome's Avatar
It very could be, and yes it does plug into map and rail but it only throws a code at 110 or so. I was really hoping for pwer over 110 or 3200 on a dyno sheet
Old Oct 7, 2007 | 06:56 PM
53 willys's Avatar
Man I think I would yank the puck and find a long safe road to see if it is the puck or the new Smarty software or what...
Old Oct 7, 2007 | 07:32 PM
MOJO1's Avatar
Good numbers! I DYNOED Saturday on a Mustang put down 450HP 950TQ I want to hit 500HP
Old Oct 7, 2007 | 08:41 PM
bluechrome's Avatar
Were you on tst's dyno? I heard that is very hard to make big power on
Old Oct 8, 2007 | 07:09 PM
MOJO1's Avatar
bluechrome
Yes i was at TST.Man it a hard Dyno to turn! Seems like alot of drag on it.
John_P
NCDTR #18
22
Jul 10, 2008 07:01 PM
John_P
NCDTR #18
55
Apr 12, 2008 03:56 PM
Dean Snow
Nov 8, 2007 03:26 PM
pwerwagn
Feb 28, 2007 03:18 AM
502502
23
Nov 23, 2005 06:16 PM
