best diy cp3 kit 07 5.9
I believe Industrials "Bag of Parts" is supposed to flow about 20% more than stock while Motorsport Diesels Arson III kit flows about 18% over stock. Either one will work for you as long you upgrade to a FASS or AirDog fuel system to supply the CP3 with the much needed fuel.
Not trying to derail the thread here. But say a guy was running a "bag of parts" for a while without a FASS or some type of upgraded fuel system. What, if any negative effects could come of that?
If using the stock LP with higher flower pump mods and bigger injectors you would basically starve the engine of fuel and put a strain on the LP more than likely causing it to fail. You would never keep enough rail pressure to make any real horsepower gains.
Oct 6, 2010 08:23 AM
Nascarcamper
Sep 13, 2010 11:03 PM
N8theGr8
0
May 2, 2009 02:23 PM
subspd
Aug 27, 2006 02:17 PM
