BD Triple Dog and options questions.
OK guys I tried to search and got thousands of possible matches. I looked through 300 or so posts and still dont have an answer to several questions. I bought the downloader used and the paperwork did not make it to me.
First question is, I think the Triple Dog can adjust for tire size but I have searched the programmer and can not find the info. Can someone tell me where to find it?
Second Question is, Can I stack the Triple Dog with the Diablo Puck?
I think the puck is pressure and the Triple Dog is timing and fuel. Is this Correct? I left the puck on the truck but have it turned off.
Third question is: how much boost should I be seeing? As of now I have seen 31PSI on my Quadzilla monitor. Is this right or do I need a boost fooler? The truck smokes some out of the hole but really cleans up when the boost comes up so I am guessing the boost is right.
Forgive my ignorance on this, I am just wanting to learn and do it right and not tear anything up.
BTW it will be going to Relentless for tranny upgrades in the next few weeks. VB and maybe convertor.
Thanks for help in advance.
What version is the software?
It's only yhr newer versions that have the tire size thing, under vehicle options or something similar.
Don't know anything about the Diablo.
30 pounds was all the boost I was getting until I got the boost fooler, now I see 40. You should get one, helps to keep things a little cooler.
No idea on the version I am guessing its older. It does have the Crazy Larry program and I dont want to loose it with an update in software.
Where can I find boost fooler? I am assuming my Quadzilla will still display the correct boost with a fooler. The Quadzill is a plug and play, not mechanical.
Sorry for all of the silly questions. It has been quite a while since I played with diesels and even before it was on a Powerstroke.
Any insight or suggestions are welcome.
Come on guys. I know it gets old answering the same questions sometimes but think back to when you started. Did you know everything? I bet not or you wouldnt need places like this.
This is the very reason I go out of my way to help guys on the ATV forums I belong to. I have quite a bit of knowlege in those areas and try to help out when I can.
So far my impression of this web sit is if you don't have a Smarty then its not worth even posting here. I had one and hated it!!!! I sold it in a week. The smoke was embarrassing at times. Don't get me wrong I liked it at imes also but not at every take off.
Click the top, "Shop DTR" and get your boost fooler from Lary.
Not sure about the Quadzilla but Lary will have an answer for you on that.
BTW, we're accepting new members:
https://www.dieseltruckresource.com/...d.php?t=230492
One thing I don't understand is wht BD is a bad word around here.
Baskin Robbins has 28 flavors of ice cream for a reason. lol
jnovotny27
Sep 23, 2010 07:55 PM
surlynkid
Aug 4, 2008 02:41 PM
Hoss 2500
Sep 3, 2007 10:43 AM
CReed
May 17, 2007 10:11 PM
JUSTIN1MC
Aug 12, 2005 12:01 PM
