Sponsored by:
Sponsored by: DashLynx
banks muffler drone
Old 12-29-2004, 07:32 PM
local601's Avatar
banks muffler drone
does anyone think that the banks muffler drones bad. I pulled the cat and put the banks muffler on and i think it has a horrible drone at 75 mph. I had an 03 with 4" and a quadzilla muffler on it and it was way better than this banks muffler. is this just the way the newer trucks are or could it be that this truck is a dually and my other one was not. i'm about to put the cat and muffler back on well maybe its not that bad but still annoying.
Old 12-29-2004, 09:34 PM
Kyle Graham's Avatar
try out the aeroturbine it helps to eliminate drone look into it if you don't want to replace with stock cat and muffler
Old 12-29-2004, 10:26 PM
Forrest Nearing's Avatar
just put a resonator as far forward as you can... you can spend $200 on the aeroturbine, or ~$80 for a dynaflex
Old 12-30-2004, 12:53 AM
AK RAM's Avatar
Re: banks muffler drone
I don't have one, but I hear that a lot. These work like a charm right at the end of the downpipe: http://shop.airflowonline.com/Mercha...ategory_Code=R
If you have access to a sawzall, pick up a couple of 4" band clamps (http://shop.airflowonline.com/Mercha...tegory_Code=S1) and you can slap one on in the driveway in under an hour.
Aeroturbine works good to, just spendy.
Old 12-30-2004, 07:38 AM
who sells the aeroturbine for 200.00?? They are alot less than that
Old 12-30-2004, 03:06 PM
RamWheelsBy4's Avatar
I have the Banks Monster 4" Catback system on mine. I dont really have a drone at any cruising speed. It is a little annoying when accelerating with a load, but not bad. I still have the Kitty, so I am pretty sure it is acting like a resonator.
Old 12-30-2004, 03:13 PM
just FYI, you can get stainless torca clamps at Truck Pro for less than that...
Forrest
Old 12-30-2004, 05:23 PM
Hounddog's Avatar
No drone.The stock had a DRONE!
Old 12-30-2004, 05:52 PM
Nascarcamper's Avatar
I'm still pondering the AeroTurbine or something like it... YES drone is present.
Old 12-30-2004, 05:55 PM
Car_nut57's Avatar
Kyle is right if you have removed the cat and are getting a drone, the best fix is an Aeroturbine all the way in the front of hte system righ tunder the passengers feet. It will not only stop the drone, but will also lower EGTs even more.
800rmk
04-03-2009 06:19 PM
wvopowered
03-29-2009 03:08 PM
Spooler
02-25-2008 11:04 AM
Jmac
10-10-2006 11:52 PM
bradmulvey
14
01-27-2006 12:18 AM
Quick Reply: banks muffler drone
