B-D high idle kit
Old Feb 6, 2007 | 02:17 PM
jmccart's Avatar
B-D high idle kit
Anyone know anything about this item?
http://www.bd-power.com/ram/product....e%20Kit&tt=ram
Thanx.
Old Feb 6, 2007 | 05:49 PM
Howling's Avatar
Why not get the dealer to enable the high idle or borrow a Bully Dog tripple dog and enable it yourself.
Old Feb 6, 2007 | 06:19 PM
ptgarcia's Avatar
Next time you're in the Rancho Cucamonga area let me know and you can use my Triple Dog to enable everything.
Old Feb 6, 2007 | 06:36 PM
jmccart's Avatar
Thanx Pat. I think for a manual tranny, to do it from the factory, you have to get a plug for one of the ECM receptors. Are people having this work on manual tranny trucks with the bully dog?
Old Feb 6, 2007 | 07:58 PM
DODGE4X4's Avatar
Ground your 22 Pin on your computer.
Old Feb 6, 2007 | 11:34 PM
jmccart's Avatar
Hey Dodge4x4, do you happen to know where there is a diagram I can view for htis on-line?
Thanx.
Old Feb 7, 2007 | 11:40 AM
jmccart's Avatar
FYI, I contaced BD. It is for Chevy/GMC only.
Old Feb 7, 2007 | 11:47 AM
MikeyB's Avatar
Hmmm. Wonder if it will work on the '03 models....
MikeyB
Old Feb 7, 2007 | 08:48 PM
06dodgedrw's Avatar
last i check the dealer cant and wont turn the high idle on with the manual. i was told that the auto shuts off when you press the brake to put in gear. like my 6spd and prolly all otheres when the truck idles up to 1000rpm(when cold) you can pop the ebrake and take right off with it still at 1000rpm. so if you had that option you'd be dumpin your clutch with the idle up and lite up the tires but it dies with either the brake or a touch of the throttle
Old Feb 7, 2007 | 09:47 PM
stock03's Avatar
MikeyB
Me too......
Old Feb 7, 2007 | 10:10 PM
jmccart's Avatar
Read page 3 of this thread, it is interesting. A guy does it to his manual trannsmission truck, but there is a plug for the ecm that must be installed.
http://www.flashpaq.com/forum/viewto...r=asc&start=30
Old Feb 7, 2007 | 11:16 PM
BlueDually's Avatar
dieselservices.com makes a electronic high idle kit that works on all 98.5-07s, I have one on my 04.5, works fine.
Old Feb 8, 2007 | 01:12 AM
jmccart's Avatar
Thanx Bluedually. I just checked it out. I was very excited, but I must say, the $439.00 price kind of surprised me. It does sound just like what I want. Better than the factory because you can adjust the idle to your liking with a dial.
Thanx.
Old Feb 8, 2007 | 07:37 AM
RAMRODD's Avatar
Thanx.
If you ground pin 22 and have the dealer enable the high Idle you adjust your idle with your cruise control (better then adding another dial IMOP)
Old Feb 12, 2007 | 12:33 PM
jmccart's Avatar
Hey Ramrodd, is the factory cruise control high idle adjustable, or is it an on or off set up? I thought the factory high idle was set at one RPM onley.
Thanx.
