attitude monitor?
attitude monitor?
I have done searches into the accuracy of the edge monitor as far as boost pressure and such. I cannot find a existing thread noting the accuracy of the tranny slip function. I use the chip on level 4 and 5 more than i should on a stock 48re and I am seeing about 5 - 9% slippage at the most some times. What I would like to know is how accurate are these readings? Is the tranny slipping more or less? Any help would be much appreciated.. thanks.
doesn't really matter if it's 1% or 20%. Slippage is slippage and it is doing damage. You can actually feel it slip without looking at the monitor, right? I know I could. I'm bettin' if you drop the pan, the big magnet in the bottom is not clean. You need a torque converter. I just installed mine last weekend. No more slip.
nitis
02-26-2007 07:38 PM
Hondo
03-03-2005 06:40 PM
powerstrokin03
13
10-18-2004 09:07 PM
Slice
08-17-2004 04:32 AM
