Arson III or Aftermarket Pump?
Old Feb 18, 2010 | 12:25 AM
D45's Avatar
D45
How does a stock CP3 with the Arson III kit compare to a Level 1/Stage 1 or Level 2/Stage 2 pumps?
Just trying to decide what route will be best.....
I know the level the Level 1 pumps are essentially flow porting modifications, this removes passage restrictions, the internal supply pressure is also bumped up considerably.
A Level 2 has the above mods done, plus the displacement is increased by 18%.
Wicked Diesel:
Level 1: Supports up to 700hp; 223lph displacement
Level 2: Supports up to 750hp; 263lph displacement
Industrial Injection has a 33% over stock pump also.....
Or, with my truck's mods, will the Arson III be plenty?
Arson III:
Supports stacked programming
Handles oversized injectors
Faster rail pressure increase
Higher sustained rail pressure
All new Bosch components
Unmatched real world results
Has supported over 700hp
Old Feb 18, 2010 | 08:40 AM
1985cucv's Avatar
how many miles on the stock pump? if it is in good working order i would say that you are fine with the upgrade kit for 400 bucks no reason to reinvent the wheel!
Old Feb 18, 2010 | 12:43 PM
D45's Avatar
D45
About 72,000 miles on the stock unit
Old Feb 18, 2010 | 06:02 PM
1985cucv's Avatar
id prolly buy the kit and save your self a thousand bucks i might do the same and do it mine has 74000 on it now
Old Feb 18, 2010 | 06:57 PM
SuperiorRam's Avatar
I'm gunna throw the arson 3 on here soon is just sitting in the box waiting...
oldblu
Dec 18, 2010 11:25 AM
SMKHZRD
May 3, 2010 08:28 PM
CTD2001
31
Aug 30, 2009 07:54 PM
2007 5.9
Mar 21, 2009 01:45 AM
Stainless
Aug 20, 2008 09:23 PM
