Anyone used the Edge Insight?
I have the Insight in my 07.5 right now. I've never had real gauges, and I don't have the EGT probe in yet, but you can get trans temp, boost, and a bunch of other parameters with it by just plugging it in. By looking at the menus, there are a lot more things being monitored by the Chevy's computer.
3DK
3DK
Plugs easy, I have the EGT probe and works great, plugs to the OBDII (bottom dash by the brake pedal) and pyro.
You can display from 2 to 7 parameters at once; I am currently using 4 displays, EGT, Boost, Trans Tem, and Fuel DIpsi.
Set on green color with 50% contrast.
Alert Alarms set at:
Speed 70, EGT 1300, RPM 2300, Boost 30.
Many other options to go with.
This set-up is to monitor Smarty senior (sold) and now going with Smarty Junior. Edge Pillar mounting is easy to install and match the color perfectly
I had 2 regular pillar gauges before the Insight.
So, I called Edge Products and asked them about it.
The Edge Technician told me to: from the screen selection go to “Chrysler”, then to pick the “Air” section, then to pick “Vac-Boost”. I followed the instructions and it worked, the readings are the same or similar to the readings from my other gauges.
IMO, it is the Smarty of gauges, If Marco and/or Bob would produce something like that or similar, they would dominate the market.
About $400.00 and EGT is the only other plug.
Your information is correct. After installation, when I choose “Boost” as one of the parameters for the screen, there was zero reading (and yes I drove the truck) with a sign in the screen of N/A.
My thoughts exactly........
Can you get the insight for an 05? I think I saw on the edge web sight that it is only for 06 and up. I only need it if I end up trading for an 05 and my juice/attitude won't work, then I wanted to get the smarty and insight.
FATCAT
Sep 20, 2008 11:08 PM
Cummins610
Feb 5, 2008 09:50 PM
bggrndodge
13
Feb 4, 2008 08:37 PM
kcbarnes
May 4, 2004 11:08 AM
