anyone with a triple disk tq
I have an "ATS Triple-Lok" TC in my 2006 Dodge CTD CR. This converter has been in my truck since it was new going on FIVE (5) YEARS now. That same converter was in my 2002 Dodge CTD for about three years before that and all ATS did to it was update the internals and change the stall speed some for the CR.
I have NEVER had that code in my 2006! The truck has about 115,000 miles on it now.
John_P
John_P
Sorry, just thinking out loud.
The code that generally shows with a tighter converter is around TCC lockup performance. The ECU sees an rpm drop that is outside of its paramters, something like 300-800 rpms. You get 1 code if it is too tight or too much slip. The ECU doesnt designate which one.
The only wire I can think of thta would negate that code is the output speed sensor return circuit. A resistor would consistently make the reading lower than normal and would solve the problem. As long as that output was not critical elsewhere then it would work.
mhuppertz
Apr 3, 2010 05:14 PM
winkdemon
Aug 3, 2009 04:13 PM
Mike D
Dec 9, 2008 07:59 PM
cconrad331
Jan 27, 2008 09:47 AM
DSjockey
34
Jul 20, 2007 07:03 PM
