Is anyone running 255/80/17 tires on a Dually
Old Nov 18, 2009 | 08:44 AM
  #46
PowerstrokeThis's Avatar
Originally Posted by Ernst223
What size toyos were you running? How's the size compared to the bf's?
you can get the same size toyos that are in my sig in a load range E and they last a pretty long while
Old Nov 18, 2009 | 09:54 AM
  #47
BlueDually's Avatar
I had 295/70/17s, with 2'' spacers in the duals.
Old Nov 18, 2009 | 07:38 PM
  #48
Ernst223's Avatar
How do the BF's compare on height? Do they do good in mud?
Old Nov 18, 2009 | 11:07 PM
  #49
BlueDually's Avatar
I dont know, maybe a inch shorter. Seem easier to turn on the highway to. Not as much mass. Theyll do good in the mud, alot tread there, they should clean well to. I havent had a chance to try them out yet.
Old Nov 19, 2009 | 09:54 AM
  #50
levigarrett76's Avatar
Thanks for the pictures! They look good! MY concern is how the blocked outer tread holds up to our heavy flatbed dually! The ability our stock wheels give us to rotate may help some, but im worried I will have to rotate every 5,000 miles to keep them from cupping on the shoulder like i did on my old bfg m/t's on my 2002 7.3 f-250.
If i felt like i could get the miles out of them i did with my last set of BFG muds (93k) I would be all over them, I have heard in the rockcrawling community they are a softer tread compound, but thats a rumor?
I still need a taller (somewhat skinny) tire or some taller gears, It still looks like gears might be the best option.
Old Nov 19, 2009 | 04:02 PM
  #51
Ernst223's Avatar
Does anyone have any idea how many miles these BF's are going?
Old Nov 19, 2009 | 04:04 PM
  #52
Ernst223's Avatar
I currently have a set of 265/70/17 cooper stt's and have a little over 40,000 miles, but they are just about done. For a m/t 40-50,000 is not too bad in my book. I would buy another set of these, but would just like something taller, but still wider than the 235's without running a spacer.
Old Nov 19, 2009 | 04:15 PM
  #53
AH64ID's Avatar
I think they are too new to tell..
That great considering my Toyo AT's are about done at 32k.
Old Nov 19, 2009 | 04:44 PM
  #54
MikeyT's Avatar
Why not just get a spacer? I'm running 35/12/5-R17 Open Country MT's on my dually with a 2" spacer. Load range E, great aggressive tire and siped so they don't suck in the winter.
55,000km so far and wearing well.
Old Nov 20, 2009 | 05:56 AM
  #55
So the back tires are covered by the fender
Old Nov 20, 2009 | 07:45 AM
  #56
Ernst223's Avatar
I haul way too much weight to run a spacer, usually between 25-32,000lbs. Just don't feel comfortable with the idea.
Old Nov 20, 2009 | 07:44 PM
  #57
same here, most i usually pull is 27,500
Old Nov 21, 2009 | 02:00 PM
  #58
Ernst223's Avatar
What size tires are you running now levi?
Old Nov 21, 2009 | 04:08 PM
  #59
bruce03's Avatar
Thanks for the pics BlueDually. I've been waiting to see what they looked like on a dually. Looks like I found my next set of tires. A little taller but no need for a spacer in the back.
Old Nov 21, 2009 | 04:26 PM
  #60
I got 66k on my stock 235/80 generals. Since im a cheap **** i met a guy and got another set of takeoff generals with 10k or so on them as well as a full factory exhaust system for 350 bucks. I think I am going to change them out at 70k.
If someone would ever come out with a 255/80-17 in a more highway friendly tread that can take some weight i will be all over it.
MY old powerstroke with the 35 bfg muds that went 93k...I towed 5-15k fairly often, but that truck wasnt as front heavy as mine, and i rotated them every 5000 miles
Im just scared of buying these bfg's being softer and not being able to take the weight.
