Anyone have a Triple Dog I can borrow...
Old Jan 5, 2007 | 03:30 PM
RamWheelsBy4's Avatar
Originally Posted by RamWheelsBy4
The Bully Dog Triple Dog and the Smarty must be VIN locked to enable any options or change the ABS tire size setting. When you remove either of the downloaders completely your settings will return to what they were. At least that is my experience with the two downloaders.
Well after thinking about it I never used the Bully Dog Triple Dog to change any of the "other" options, so I will have to change that to I don't know about the Triple Dog.
Old Jan 5, 2007 | 04:10 PM
CowboyDave's Avatar
Nope, I just removed mine a few days ago, then lastnight I used the BDTD to put the high idle feature on. All I had to do was plug it into the OBDII and then turn the key forward and selct the option. Keep in mine I have no BDTD downloads right now, completely removed.
Old Jan 5, 2007 | 07:02 PM
Argo's Avatar
can you use a BDTD from an 03 on an 05? if so I wanna use cowboydaves to do the highbeam thing.
Old Jan 13, 2007 | 04:47 PM
arcojet's Avatar
Any verdict yet??
Old Jan 13, 2007 | 06:28 PM
Little03's Avatar
this is off topic but i cant get my high idle option to work on my 03 unless im dumb cuz at -15 my truck automatically bumps to a higher idle about 1000 rpm, but only when the outside temperature is below zero it dose this. so is that the high idle option from my bddl or should it kick it self to a high idle even if its 15+ out side?
Old Jan 13, 2007 | 06:36 PM
CowboyDave's Avatar
Shoot boss I havent been able to do it either. I just figure it would work, untill today. Its cold out and I wanted to warm her up while I got dressed, but it didnt work. I dont know if Im missing somthing either.
Old Jan 13, 2007 | 07:21 PM
ptgarcia's Avatar
I got the Triple Dog and enabled everything. It worked like a charm and was easy to do. And you don't have to have the program downloaded to do it.
About the high idle deal: Our trucks will automatically bump idle up to 1000rpm when the temp reaches a certain low, on my truck its around 30*. The cruise control controlled high idle, which must be enabled by the dealer, Bully Dog, etc. can be operated no matter the temperature.
Hoss 2500
Sep 3, 2007 10:43 AM
acook
22
Sep 23, 2006 12:46 PM
RamWheelsBy4
Sep 17, 2005 01:43 PM
JUSTIN1MC
Aug 12, 2005 12:01 PM
