anyone else problems with south bend clutch?
Old Feb 10, 2009 | 08:38 PM
cr25ovet's Avatar
i had mine for about a year(12000miles)no hauling. i was getting new tires today and was going to smoke my old tires. well it didn't work. the clutch was slipping and the tires weren't. now i can't get the truck to shift anymore. the clutch was rated 550 hp. i barely make 400hp. i am a little mad.
Old Feb 10, 2009 | 08:40 PM
Totallyrad's Avatar
Have you contacted South Bend yet?
Old Feb 10, 2009 | 08:46 PM
cr25ovet's Avatar
no i just send them an email. i had the truck towed to the diesel shop i use. so maybe they can figure out whats wrong. is there any kind of warranty?
Old Feb 10, 2009 | 08:48 PM
lmills's Avatar
you won't find any manufacturer in the industry that stand behind there product better than South Bend. Peter will take care of you if the clutch is defective
Old Feb 10, 2009 | 08:54 PM
Totallyrad's Avatar
I don't know what their warranty is but there are a number of things that could have been done wrong during the installation. Some things that could cause the clutch to slip may not show up right away. It could be bolts backing out, fluid on the clutch, who knows. I'd wait to see what the mechanic says before I'd blame the clutch. I might also be standing there when they drop the tranny, just to keep everybody honest.
Old Feb 10, 2009 | 10:16 PM
cr25ovet's Avatar
i noticed right from the beginning that there was always a 3-4% slippage in 6th gear on the edge dispaly. i didn't think much about it....
the shop i use are honest people. i have the truck towed 60 miles just to have the shop work on it. thats the only diesel shop i trust. i could have towed 4 miles to the next shop but i rather pay 230$ for towing. well we will see what happens.... but with my luck i am gonna get a big bill again... you live and learn. bad thing only about that is at one point ya die and forget all about it lol.
Old Feb 10, 2009 | 10:36 PM
Snoxracer's Avatar
I bet you tried to do a little power braking a slipped the clutch and burnt the plates a little bit. And now the clutch will not completely disengage not letting you to beable to shift, but most will come out of it with a little driving. Our pulling clutch would do this when it was new but now works like a champ. But it is a dual disk with 3850# plate. But talk to Peter he'll set you up right!
Old Feb 11, 2009 | 08:45 AM
XLR8R's Avatar
My new South Bend DD is making the 37"s bark in every gear - Peter told me it was the loose nut behind the steering wheel...
Old Feb 11, 2009 | 06:28 PM
cr25ovet's Avatar
got everything fixed. thank you south bend clutch!! they do stand 110% behind there product!! wooow.
Old Feb 11, 2009 | 06:37 PM
6006spd's Avatar
weird,i have a 3850 in mine and i beat the$$$$ out of it 3rd gear launches,i tow heavy lots as well it is a grabby clutch not great to try back up a trailer with but it never gives up!forget the emails call peter at s bend he will make it right
Old Feb 11, 2009 | 06:38 PM
matego's Avatar
madhat's monkey boy...
My guess is that you have a ferramic clutch since you said it was rated at 550. I have had bad luck with ferramic lining holding up. The last ferramic clutch I blew out had pieces of the clutch welded to the flywheel, it was pretty ugly. Another one I welded the disc to the flywheel, not a good time either.
If you are going to beat it, go full ceramic. I have fried mine countless times and after you let it cool its good to go again. One time I did a 3rd gear launch at the track and it slipped out of the hole. I was mad so I smashed it the whole 1/4 with it slipping. Let it cool and it was good again.
Old Feb 11, 2009 | 06:42 PM
Pooter's Avatar
Give Peter a call, stand up guy for sure.
Old Feb 11, 2009 | 06:57 PM
Easy_C's Avatar
I just had a problem with mine that they took care of....
https://www.dieseltruckresource.com/...d.php?t=232857
Old Feb 11, 2009 | 08:08 PM
Chris Blevins's Avatar
You can also take a bone stock truck with a clutch that is rated at 550hp and burn it out sometimes it's how you driver error, not saying it's your fault but their are many things to consider here. Peter is great to deal with and stand behind his products!!!
Old Feb 11, 2009 | 08:57 PM
Spooler's Avatar
Sounds like you heated it up too much and the clutch disk is now stuck to the pressure plate and flywheel or the clutch disk may have came apart. Ouch!!!! Only did that once a long time ago.
To correct the issue. Push in the clutch while the tranny is in a high gear, roll over the starter and hope it will break free,,LOL
