Anyone else building an EARLY 2004 Cummins?
Just wondering if anyone else is pushing their early 2004 Dodge Cummins with performance upgrades? Here's what I did:
90 HP nozzles from Dynomite Diesel
Water/meth injection
BD Twins
4" Stainless exhaust
TST Power MAx CR R49
Smarty
ARP Head studs
Glacier fuel pump (not yet installed)
ATS Billet transmission (input shaft, flex plate, co-pilot, torque converter)
I think I should have got the "Race Track" twins from BD. Yet I haven't turned the boost up on the standard twins just yet. I get about 42 right now. At this boost I believe they are barely working!
Dan
BD Twins
Smarty
ARP Head studs
Dan
I am with mine... have a few more upgrades going in end of month. Not all stuff is in sig. i think you should have gotten the race twins too!! Although I do know one guy that has the tow twins and has pushed 70+ psi with them.
early 04 here its been fun playin around with it, but i think i need to step up to twin turbo set up. running 80 mph i am at 5 lbs of boost and the temps stay around 650-700 but i have a constant haze of black smoke while driving and just hit the cruise button to speed up another 5mph or so and boost jumps straight to 40 and i black out everything behind me. it seriously never cleans up at all
How does the diy cp3 perform? Was it difficult to do the modification? I read someplace where they show you step by step to do it. When they said grind a larger oval in one of the cp3 pieces I became nervous. I'd probably screw it up. I did all the work myself on my truck and I am fairly good with tools, but I don't know if I'd trust myself with my stock cp3. Any performance increase?
That should not be so. Im not doubting nor was I accusing you of bragging about it I was just saying the rated hp was 305/555 and in o4.5 it switched to 325/600 and in 06 it changed again. Was the California model detuned that much. Surley not thats alot.
Nick.
Moobesor:
With the mods you have listed, you are capable of asking for more fuel than your cp3 can deliver. You need more than a DIY mod... suggest at least a Floor IT stage 1 Cp3 and you are better with a stage 2.
