Anybody running 37 13.50 tires?
Old Jun 2, 2006 | 11:12 PM
05 DIRTY DODGE's Avatar
Would like to know anybody running this combo. Already bought a set of wheels that didn't work. 17 x 10 with 4.5 backspacing doesn't work. The 13.50 size I want to keep. Any pics would be great, also need to know backspacing and rim, 18 or 20 are cool might have go that way. Thanx
Old Jun 2, 2006 | 11:26 PM
Jeff K's Avatar
yup, pics are in my gallery. I am running Mickey Thompson 17x9 wheels with 5" BS and they work fine, no rubbing
Old Jun 3, 2006 | 11:15 AM
PWT05Dodge's Avatar
I'm not sure about 13.5" tires, but my 12.5" tires work great with H2 rims. I looked and there is room for the tire to be wider, so they should work. Cheap alternative for you IMO. And it'll keep you at stock backspacing.
Old Jun 3, 2006 | 12:31 PM
Lsufan78's Avatar
this combo is not recommended with out a good bit of lift. it rubbed real bad on the rear of the front fenders when turning with 5"s of lift. the last pic is with 2" spacers (7"s total), and i can still get them to rub with the axle articulated and the wheels turned. i'm waiting on a set of long arms to push the axle forward some which will cure all rubbing problems. btw...those wheels are diamo 17 karat 17x10 with 5.25" b.s. -12mm offset. hope this helps some.
later, dustin
Old Jun 3, 2006 | 12:34 PM
Lsufan78's Avatar
forgot one, this is where it rubbed (rubs) on the fender
Old Jun 3, 2006 | 09:05 PM
rockittboy's Avatar
check my gallery, those are toyo 37x13.50 on stock rims, only slight rubbing on the CA's at full lock, no probs in 25k miles.
Old Jun 3, 2006 | 10:15 PM
marc03's Avatar
mine are 18x9.5 w/ 6" of backspacing. My tires are 13.5" wide. They rub the control arms slightly at full lock, but NEVER the fenders.
Old Jun 4, 2006 | 02:17 PM
Luvnacumns's Avatar
37's
I am running 37x13.50x20's Toyo mt's and they rubbed a little on the front air dam. I just took that off. I have never had them rub the body! I have pic's but can't figure out how to post them!! If someone could help on that I will have pic's in my profile. Thanks
Old Jun 4, 2006 | 11:07 PM
Keyser Soze's Avatar
I just ordered a set of 22x10's for my 05.. I will be running 37x13.50R22's, they should look sweet..
Valv
Aug 29, 2010 07:13 PM
1320
May 29, 2009 10:24 PM
BroncoAZ
0
May 26, 2009 02:07 PM
sakisaki400
23
Dec 31, 2006 10:17 PM
big pappa
Aug 17, 2004 09:27 AM
