Anybody running 37 13.50 tires?
Would like to know anybody running this combo. Already bought a set of wheels that didn't work. 17 x 10 with 4.5 backspacing doesn't work. The 13.50 size I want to keep. Any pics would be great, also need to know backspacing and rim, 18 or 20 are cool might have go that way. Thanx
yup, pics are in my gallery. I am running Mickey Thompson 17x9 wheels with 5" BS and they work fine, no rubbing :D
I'm not sure about 13.5" tires, but my 12.5" tires work great with H2 rims. I looked and there is room for the tire to be wider, so they should work. Cheap alternative for you IMO. And it'll keep you at stock backspacing.
this combo is not recommended with out a good bit of lift. it rubbed real bad on the rear of the front fenders when turning with 5"s of lift. the last pic is with 2" spacers (7"s total), and i can still get them to rub with the axle articulated and the wheels turned. i'm waiting on a set of long arms to push the axle forward some which will cure all rubbing problems. btw...those wheels are diamo 17 karat 17x10 with 5.25" b.s. -12mm offset. hope this helps some.
https://www.dodgetrucks.org/gallery/...m/100_0920.jpg https://www.dodgetrucks.org/gallery/...m/100_0917.jpg https://www.dodgetrucks.org/gallery/...m/100_0918.jpg https://www.dodgetrucks.org/gallery/...m/100_0923.jpg https://www.dodgetrucks.org/gallery/...um/unlevel.jpg later, dustin |
forgot one, this is where it rubbed (rubs) on the fender
https://www.dodgetrucks.org/gallery/...m/100_0919.jpg |
check my gallery, those are toyo 37x13.50 on stock rims, only slight rubbing on the CA's at full lock, no probs in 25k miles.
mine are 18x9.5 w/ 6" of backspacing. My tires are 13.5" wide. They rub the control arms slightly at full lock, but NEVER the fenders.
Pics on my page.
37's
I am running 37x13.50x20's Toyo mt's and they rubbed a little on the front air dam. I just took that off. I have never had them rub the body! I have pic's but can't figure out how to post them!! If someone could help on that I will have pic's in my profile. Thanks
I just ordered a set of 22x10's for my 05.. I will be running 37x13.50R22's, they should look sweet..
