Sponsored by:
Sponsored by: DashLynx
any true 5" exhaust?
Old 05-10-2008, 07:21 PM
fordassassin's Avatar
hey hows it going guys?well i was about to buy a MBRP 5" exhaust,though then i found out that the elbow is 4"...So it goes from a 4" to a 5" i guess..Well i was wondering if anybody makes a 5" exhaust from the TURBO BACK and a reasonable price..any help would be appreciated
Old 05-10-2008, 07:44 PM
Speed Shift's Avatar
The stock turbo and all aftermarket singles have a 4" outlet. The MBRP has a 5" downpipe that goes into a 4" flange.
A TRUE 5" exhaust will require a turbo with a huge exhaust housing, and it will be nothing you can light by itself.
Old 05-10-2008, 07:53 PM
ooo and also i have a early 04!!well Browns Diesel is going to do the truck!!though i just wanna know if any manufacturer's make a 5" true exhaust..im going to go with a 64mm turbo and i just wanna start buying the parts so i can just send it off for the labor..Brown can make a Bracket/elbow/downpipe 5",though im just checking if i can find one already made
Old 05-10-2008, 08:02 PM
slickwillie's Avatar
shopdiesel is the best ive found. $310 shipped to your door. as mentioned the turbo is 4", but with the shop diesel kit, it immediately goes to 5"...top notch system thats cheap IMO
Old 05-10-2008, 08:11 PM
yes i know that the turbo outlet is 4",though im looking for a downpipe as well that is 5"!!i looked and the SHOPDIESEL exhaust has a 4" downpipe
Old 05-10-2008, 09:01 PM
D45
D45's Avatar
I believe 04.5s have a 4.5" downpipe that will bolt right up out the 04 down pipe.
Old 05-10-2008, 09:51 PM
Since you have an early 04 you will need an HX-40 downpipe for the new turbo, the turbo back kits you buy will be for the stock turbo flange. I would buy a 5" cat-back exhaust system, a short peice of 5" pipe and a 5" hx-40 downpipe, that will save you some money.
Old 05-10-2008, 10:29 PM
Gary Emerald's Avatar
I believe 700rwhp has been done with 4" exhaust...
a 4" downpipe is fine
Old 05-10-2008, 11:57 PM
chrleb1's Avatar
Almost 900 hp has been don with 4". It doesn't make any performance changes compared to straight 4" until 650 rwhp. Even then it is only a couple of HP.
Old 05-11-2008, 12:58 PM
GlennRMK's Avatar
As mentioned above, get the 04.5 elbow.
The 5" systems for the 04.5 are just 4" right off the elbow and quickly neck up to 5". That is as close as you are going to get.
I have the 04.5 elbow sitting in the garage waiting for an 04.5 exhaust. You need the clamp too!
Even if you use a 4" system its nice to have 4" elbow instead of 3.5"
Old 05-11-2008, 01:32 PM
wap
wap's Avatar
Not the one thats on my truck, its a 5" down pipe.
As mentioned the 5" isnt worth it as far as hp goes. I did mine for the tone and would do it agian, it does sound much better imo.
Old 05-11-2008, 02:33 PM
RJ285's Avatar
How much does a 5in help with EGT's compared to a 4in?
Old 05-11-2008, 03:05 PM
Erick Brown,what size exhaust does Richard have on the single cab?im guessing its the 5",what did he do at the elbow?i remember he was telling he has a bracket that makes it 5" right from the Turbo back!!and yes i want the 5" because of the TONE and i heard it helps EGT's a bit
Old 05-11-2008, 03:57 PM
Reb.B's Avatar
you don't need 5" for what you are doing. My reg cab has 4" downpipe. You have a lot to do before you need to worry about needing larger than 4" downpipe. Main thing is not to get excited. We need to see what turbo is going on, then get the 4" elbow if needed and get 04.5 exhaust then. If you buy a 5" exhaust for an 03-04 then you will be worse because of the small elbow.
Old 05-11-2008, 04:04 PM
did u guys figure out what Turbo setup or things ur going with?because i talked to Abe and im not planning on Towing with it at all,just daily driver yet see some strip time as well thats about it.i'll send it over the tranny in a few weeks
Quick Reply: any true 5" exhaust?
