Any Thoughts.....
Old Jan 16, 2005 | 10:36 PM
triplenickel's Avatar
Any Thoughts.....
On this lift pump kit?
http://www.bd-power.com/ram/product....%20Kits&tt=ram
Old Jan 17, 2005 | 11:09 AM
Tom488's Avatar
It looks very similar to the kit from Diesel Dynamics (same Carter pump). The BD kit goes in-line, and retains the factory pump. DD's kit replaces the factory pump altogether. There's pros and cons to both... some will say that two is better than one, because either could fail, and still get you home. Others will say that it's easier to diagnose problems when you have a single pump, and that eliminating the factory pump improves servicability.
Either approach will cure any low fuel pressure problems, and should function just fine.
Old Jan 17, 2005 | 04:02 PM
502502's Avatar
BUT its still a carter pump....
I have heard they are not reliable
Any comments on these pumps?
Old Jan 17, 2005 | 06:22 PM
Deezle1's Avatar
what Tomeygun fails to mention about his truck in his sig is that its a SO!
Dom
Old Jan 17, 2005 | 06:37 PM
502502's Avatar
Dom
Hmm, I did forget... whoops
I will change my sig... I could see where 437hp is not as cool with an HO... But my sickly little SO can straight lay it down !!! (well to me at least)
So does anyone have this BD-power LIFT PUMP KIT yet?
Old Jan 17, 2005 | 09:28 PM
digger5.9ho's Avatar
Good pump for a stock truck. I would go with the air dog, fass, preporator somewhere along those lines though. I had two Carter's on my truck in less than 14 months.
digger
Old Jan 17, 2005 | 09:46 PM
lightening ram's Avatar
the stock pump will not let any flow if it quits so 2 of them inline sounds good but if the infamous transfer pump fails again {im on number 2 with 10k} your still dead in the water.
00 5.9 ctd
Feb 12, 2006 08:58 PM
kdrfarms
Feb 6, 2006 11:20 AM
Patrick Campbell
Sep 7, 2005 05:12 PM
JaMan
Mar 7, 2004 11:08 PM
