Gen 1 cummins Conv. With 4:11 gears any thoughts ?
Old Feb 5, 2006 | 04:17 AM
kdrfarms's Avatar
The Gears I got in my GM product im doing the swap in st need to find a lift to hold a cummins weight to get it done if need be ill run 35;s to lower RPMS
ANY ONE HAVE ANY THOUGHTS ON THIS ??????????
THANKS!!!!!!!!!!!!!
Old Feb 5, 2006 | 04:43 AM
BearKiller's Avatar
What engine are you taking out??
My truck sits higher in the front with the 1st Gen. in it than it did with a 6.9 Int., about an inch.
A lot of 1st. Gen tons have 4.10 gears.
Are you using a 5-speed with an OD gear??
Old Feb 5, 2006 | 09:47 AM
4.11's will work fine if you are using an overdrive trans. If not, you'll have to be happy with a 60 mph top end.
Old Feb 5, 2006 | 11:32 AM
Begle1's Avatar
Even with 35's?
Assuming 3000 RPM redline (which you can freewheel to if you're really pushing it) then you'd be going 76 miles per hour... (Assuming you have enough power, which you should have.)
With a 3200 governor spring you could freewheel up to, what, 3500 unloaded? That would be 88 miles per hour...
If you get a 4200 RPM governor with valve springs, then 4000 RPM would take you 101 miles per hour and 4500 would take you 114 miles per hour.
Maybe he'll just have to go with 45's...
Old Feb 5, 2006 | 11:36 AM
I was figuring with "normal" size tires there, Begle.
Old Feb 6, 2006 | 11:20 AM
skchevota's Avatar
Ive got 4.56 gears, and run an nv4500 and 37" tires, I cruse at 75 allday and it tops out about 94mph with a stock gov spring.
perkins
Cummins Conversions
76
Oct 20, 2015 06:23 PM
JAyers
Sep 2, 2008 11:25 PM
belgianmagic
15
Aug 15, 2007 02:37 AM
93beater
Feb 28, 2007 09:28 AM
junkhauler
Jul 25, 2006 08:59 PM
