Any one used a kelderman air ride system?
Old Apr 30, 2005 | 10:40 PM
Turbo Boy's Avatar
Iwant to run 40 in tires so I need at least 10" of lift. Any have any experience with Kelderman lift kits? Hows the ride?
Old Apr 30, 2005 | 11:05 PM
krock's Avatar
I am not sure if it's still there, but they used to have a downloadable video clip on their site. From the looks of it they duct taped a camera to the frame showing the bag's in action. They then ran it down some rough as*ed highway to show the ride. The frame never bounced once. I originally looked in to one but I chickened out when I seen the price tag .
Old Apr 30, 2005 | 11:49 PM
wyomingsmoke's Avatar
no kidding, these boys are no joke,,, When I win the lottery I know who Ill be calling, I would love to build a truck like that!!!
Old May 1, 2005 | 10:04 AM
krock's Avatar
The only thing I could possibly see as an issue with the Kelderman would be weight transfer from one side to the other, say for when your cranking a tight corner with some speed or side hilling while out doing some diggin. You would think the bags would make the truck a little more tippy than the conventional spring and block set up. But then again it is a 10" lift so you're gonna be top heavy no matter what.
Old May 1, 2005 | 11:17 AM
Turbo Boy's Avatar
I kind of wanted conventional springs too but
The Kelderman is the best looking kit out threre. As far as cornering is concerned 10'in is a lot of lift for sure but
the shocks and sway bars will have a lot of influence on how flat the truck will stay while cornering. My experience with air springs is leaks in the system. I've seen this in the 1980's lincoln continentals and the 2000 and up mercedes S class that I work on at the dealer day to day. One reassuring aplication is the heavy duty
dump trucks i've seen with this system. I'd hate to go out to My truck early in the morning and see the wheel wells resting on the 40" tires. Also I'm not sure how much it would cost to get one of thre kits that would clear the 40's. What quates have you guys have gotten?
Thanks Turbo Boy
Old May 1, 2005 | 06:04 PM
krock's Avatar
Roughly $10,000 US. I think
Old May 1, 2005 | 07:04 PM
Turbo Boy's Avatar
10k whoooooooohh nelly
Definatly big bucks, it had better be good for those kinda bucks. I sent Kelderman an e-mail this morning regauding a 10in lift. The prices on there web site are only for standard suspension kits not lifts. I'm not sure if I'm willing to spend 10K on the lift or not but must say that my truck would certainly look the way I want it with Kelderman.
Old May 2, 2005 | 06:24 PM
Wilson's Avatar
http://www.trex-tech.com/trexairlift.html
Check that site out, seems to be the same kind of deal as the kelderman but it looks better and is cheaper from what I can tell.
Not sure if they have anything for 3rd gens just yet.
I think this is the route I will take when I get some more cash flow.
Old May 4, 2005 | 11:57 AM
Patrolman808's Avatar
I think Jeff told me the kit was $3500ish, but that was last Feb. If I ever get another lifted truck, it will have his kit on it. Just gotta get those **** lotto numbers to match up....
Old May 4, 2005 | 03:29 PM
bigblock2stroke's Avatar
FMS Ron Jeremy Cam.
Wonder what that means?
LMFAO
Old May 4, 2005 | 07:47 PM
underwoodtransp's Avatar
I found the kelderman kit for my stock height dually to be $2500. thats not to bad. I think that will be coming soon!!!
Old Jan 12, 2006 | 04:30 PM
I knew I was right. I was looking for the kelderman kits today and was thinking that $3500 seemed a little higher than I remember. I should have baught one in may!
Old Jan 12, 2006 | 05:41 PM
BigBlue's Avatar
I've seen that kit on two trucks and it's more than impressive. It's down right phenomenal. One of the guys (and I can't remember his name to save my life) said he towed 10K lbs with it with no problem at all. It really is a very well thought out system. The guy said he's never had any leakage issues at all.
Old Jan 12, 2006 | 11:04 PM
Gypsyman's Avatar
I've towed cross country and heavy A LOT with the full system. It was worth every penny to me. Small leaks will happen after the initial install and just take some time to track down. Once you fiddle with it a little bit it will be perfect and leak free.
Richard
Dr. Evil
Nov 20, 2003 03:21 PM
jeff kelderman
Mar 25, 2003 11:04 AM
jeff kelderman
0
Mar 25, 2003 09:23 AM
Luke S
Mar 24, 2003 06:59 AM
