any one running a sun visor?
Well, do you mean something like this?
Mind is a Lund visor, and is the Aero model I believe (meaning rounded corners instead of square).
It's not very noticeable from in the cab, unless you lean forward. It does block the cab lights somewhat as well from certain angles.
As far as mounting goes, I dropped the headliner and was going to use bolts and nuts instead of the supplied lag screws. However, after seeing how much harder it would be to use bolts, I just used the provided lags.
I've had mine on for over a year now, and it is as solid as the first day I put it on.
--Eric
--Eric
turbov6joe
15
May 1, 2005 08:02 AM
billyrae
Apr 12, 2005 10:31 PM
