Any guages that work of off OEM probes??
Old Jun 5, 2006 | 02:18 PM
Mike M's Avatar
Any guages that work off of the factory probes?? Looking for something that plugs into the existing system that will give the EGT, Trans Temp. boost would be nice but if not is OK. I have seen some of the power boosters that have digital read out, but don't know if that is what I need.
Old Jun 5, 2006 | 02:37 PM
staarma's Avatar
I know boost comes off of the BUS but I know EGT does not and I'm not sure about trans temp.
Old Jun 5, 2006 | 04:05 PM
Mike M's Avatar
Thanks for the reply, hopefully someone else will know if it is possible
Old Jun 5, 2006 | 06:43 PM
Jfaulkner's Avatar
Muted User
Boost is the only one that is remotely possible since there isn't a factory EGT or trans sensor.
Old Jun 5, 2006 | 07:13 PM
Mike M's Avatar
How does the Trans & EGT send info to the computer that regulates everything??
Old Jun 5, 2006 | 07:20 PM
StrokeThisCTD's Avatar
There COULD be a trans temp sender to alert when the trans is too hot, but the computer doesnt regulate EGT.
Old Jun 5, 2006 | 07:22 PM
Mike M's Avatar
Thank you for your info, guess I will have to figure out were to 3 guages, was looking for one digital that would do it all,
Thanks
Mike
Old Jun 5, 2006 | 07:36 PM
displacedtexan's Avatar
If all you want is an all in one moniter, check out the Bully Dog Outlook, or the Edge Attitude...
Old Jun 5, 2006 | 07:57 PM
bigwheels94's Avatar
The BD-X Moniter uses the factory sender in the trans.(Yes,it gives temp. it just activates an idiot light above about 230*.)The boost comes from a boost bolt,& you have to install a pyro for ANY set up.The Outlook moniter,& Attitude use the factory databuss connector & read straight from the computer,but you will still have to install your own pyro lead to get EGT's.
Old Jun 5, 2006 | 08:35 PM
Mike M's Avatar
Thanks, I will look into those options
Mike
LOGAN
Jun 24, 2007 11:31 PM
User Name:
Jun 9, 2007 02:15 PM
texasredrider
Nov 7, 2006 06:44 PM
06dmc
Aug 12, 2006 01:39 PM
AkitaSumo
Jul 23, 2006 09:57 PM
