Another Version -- AD150 Install on a MegaCab
Old Jan 10, 2009 | 07:37 PM
  #31
Polaraco's Avatar
Old Mopar Aficionado Extraordinaire
Originally Posted by Festus
I have no experience using that stuff. If you think it'll work.............take lots of pics and let us know the results. Options to this stuff are always good.
Heck! It's flexible, impervious to oil, and is a smooth bore. First restriction would be the fitting at the top for the hose.
Sounds like a plan
Old Jan 11, 2009 | 02:03 AM
  #32
Festus's Avatar
Just a suggestion - use a hose clamp and secure it to the side of the canister so it stays on the bottom like I did mine with the stiff portion of the draw straw. You'll have to cut two slits in the side of the canister to feed the clamp band through. There is one of my pics that shows the clamp on the outside of the canister on mine.
Also, can copper be soldered to brass?? Just thinking. If it can, the nipple that screws into the bottom of the bulkhead fitting (may have to cut the "lip" off the nipple), flare the copper tube, slide over the nipple, and solder..............that would be sweet and guaranteed not to leak if it can be done.
You might be on to something new and intriguing - never heard of that been done before. Take lots of pics and let us know how it goes.
I like it!!
Old Jan 11, 2009 | 10:49 AM
  #33
Polaraco's Avatar
I like it!!
Yes brass can be soldered to Copper. I was going to fore go the bulkhead connector and just drill through the top with a tight drill and epoxy it in. I can solder a street L on the top, use a close nipple and put the push on fitting on. Done Same with the return.
I saw the strap on the bottom. The only thing I have to figure out is how i am going to figure the length. I guess I can put some sort of a spacer under the copper, push the assembly into the tank and mark then. If it do it right, the Street L on the top will hold it up and the clamp at the bottom. Simple
Old Jan 11, 2009 | 10:58 AM
  #34
Festus's Avatar
If it helps for measurement, the springs compress 1/2" to 3/4" when seating it in up top.
When the tank bottom does expand and contract with weather, or weight of fuel, and / or both, I figure the tank bottom has up & down movement anywhere up to the 1/2" - depending on conditions of course.
Old Jan 11, 2009 | 11:05 AM
  #35
Polaraco's Avatar
I agree. It's almost like I need to have short piece of hose at the bottom. But I think I can allow like 9/16 and slit the edges of the tube like I mentioned before. I won't even have to grind away all the plastic reinforcement then. Pretty cool. and cheap.
Old Mar 30, 2009 | 03:50 AM
  #36
ctd4stan's Avatar
Festus,
You mentioned that you put your suction line almost at the bottom (unless I missed it), how far down did you put the return line into your fuel canister?
Old May 18, 2009 | 03:17 PM
  #37
Festus's Avatar
Originally Posted by ctd4stan
Festus,
Wow - Sorry! I never saw this question. I must have been away at work when posted.
My return drops to just above my OEM pump. I use the fuel dropping onto the top of the pump as a demister pad like in an inlet separator in the oilfield.....liquid / gas (or air in this case) drops onto the pump, fuel drops to the bottom of the canister for more entrained air free fuel to be sucked up, and any air bubbles up away from the suction line.
Old May 18, 2009 | 03:20 PM
  #38
Festus's Avatar
Originally Posted by StealthDiesel
Festus,
Unfortunately, the electric fuel pressure sender will not likely survive the mechanical vibrations of being mounted directly to the CP3 & the engine.
The snubber is a good idea but I recommend that you use a rubber extension hose (eg. grease gun hose) to isolate the sender from engine vibrations.
Or you could do what I did & tee into the rubber inlet hose to the CP3.
Just a suggestion....Joe
You were perfectly correct Joe!
I blew up (2) heavy duty senders. Now, my Commander has been down in Fort Worth since early May for the transducer upgrade. I hope its back soon.
Old May 18, 2009 | 03:38 PM
  #39
Polaraco's Avatar
I ended up doing exactly that on suction tube. . . I found a pin hole in my suction tube. I cut the tube off and used a double ended 1/2" barb. I heated the tube with a heat gun and pushed the barb in. Put the hose. Slipped it into the hole and then put the clamp on. I made the hose long enough so it would just lay on the bottom back by the stock pump. I slit an opening in the bottom so the hose could suck right from the bottom and not get sealed off.
This weekend I ran it down to about 4 gallons with no issues so I have to say it saved my butt. I just put the return in the neck like the instructions said.
Old May 18, 2009 | 10:58 PM
  #40
ctd4stan's Avatar
No worries. Thank you for responding. You provide very good detail even for a novice like me.
Old Jul 22, 2010 | 08:42 PM
  #41
Festus's Avatar
Update: transducer still working perfectly.
Old Mar 27, 2011 | 07:18 PM
  #42
metal_miner's Avatar
The draw tube is a combination of the 1/2" supplied draw straw, cut with "feet" to sit right on the bottom of the cansister and held in place with a hose clamp, and teflon 5/8' corrugated hose up to the bottom of the bulkhead fitting.
Festus-
For these "feet" ... did you just cut multiple vertical slits around the circumference of the tube and then flare the cuts out so it looks like an engine intake / exhaust valve?
-Thanks-
0524VHO
Jul 5, 2008 01:30 PM
jgiachino
Apr 8, 2008 08:54 AM
jmccart
Feb 13, 2008 11:45 PM
jmccart
Feb 13, 2008 11:42 PM
jmccart
Feb 13, 2008 04:35 PM
