another question
Old May 24, 2011 | 09:01 PM
southerman's Avatar
another question
with all after market lift pumps do you have to drop the tank? if not which one? thanks
Old May 25, 2011 | 04:29 PM
anoldbiker's Avatar
I'm limited on this, but I have looked at everything I could and all I found was either drop the tank or raise the bed.
Old May 26, 2011 | 12:32 AM
sr4440's Avatar
it depends, if you have a external lift pump then you can install a raptor 100 without dropping the tank or raising the bed.
Joe
Old May 26, 2011 | 08:31 AM
anoldbiker's Avatar
Joe
Stand corrected, I didn't noticed his year. But for all in tank applications, I only know of the two ways, is there another ? If putting on something like a raptor to replace an in tank pump, how else can you put in the draw straw ?
Old May 26, 2011 | 09:06 AM
sr4440's Avatar
I believe if you have a in-tank pump you have no choice but to either drop the tank or raise the bed. even if you went with installing a sump, you would still have to do one or the other.
Joe
Old May 29, 2011 | 05:03 PM
sojoe's Avatar
Any chance cutting a access(not a bubba patch) panel in bed-to get at lift pump, What I am asking IS HAS ANYONE DONE THIS?
Some older trucks had an access panel you could remove to service the fuel sender-so why not put a panel in the bed deck??
Just a thought-would be a lot easier than dropping the tank.
HMX-1
Introductions / New People
Sep 19, 2009 08:24 PM
Ls1z28fbody
Nov 27, 2006 08:03 PM
snowrodeo
Oct 9, 2006 09:11 AM
Jezzhuntin
Aug 25, 2006 02:51 PM
