Another Airdog question -
Well I am thinking of getting an air dog soon, I was going to go with the 100 because I dont plan on doing anymore than a smarty jr and maybe a slightly bigger turbo, mainly because I am in school for the next two years, after that who knows what will happen, I will most likely not mod any further due to wanting a new boat instead (nordic, Sunsation, Fountain, Etc.). Anyways, recently I had the LP replaced under warranty, so they did their "fix" and put it in the tank, so my question is if I buy an airdog when I install it will I have to remove the in-tank LP?
Not to throw a wrench in your plans, but the OE LP provides plenty of fuel for a Smarty Jr. Spend your money on a big line kit and a FP gauge... And put a Baldwin PF7977 in the OE canister, its a better filter than the 2 AD filters combined.
Depends on where you get your AD feed from, if you take it from the canister using the stock feed YES you will need to remove the pump but then you'll also need to rung the AD return back to the canister.
If you use the draw straw in the middle of the tank no, the stock pump can stay.
trailinone
Mar 14, 2010 10:57 AM
kdbvulcan
20
Dec 6, 2008 04:34 PM
Jezzhuntin
Aug 25, 2006 02:51 PM
