Amsoil Bypass Filter
Old Nov 27, 2012 | 11:09 AM
justen920's Avatar
I recently bought a Bypass Filter with the bracket and need to know what size bolts to use to attach the bracket to the engine block next to the grid heater. Mine did not come with these bolts and any help will be appreciated.
Old Nov 27, 2012 | 11:48 AM
rockcrawler304's Avatar
Which bracket do you have?
the one I used mounts to the intake area and uses one of the factory bolts and the other 2 used are the same.
I think they are a 10mm 1.5 but not sure.
Old Nov 27, 2012 | 01:01 PM
justen920's Avatar
I bought this type of bracket, but my truck is missing the bolts on the block, it has one hooked to a hose but missing the others, is this normal?
https://www.dieseltruckresource.com/...um/bracket.jpg
Old Nov 27, 2012 | 08:49 PM
If nobody posts up the actual bolt size and type, I'll pull one out tomorrow for you and check.
I'm not sure about the one hooked to a hose. Can you take a pic?
Here is kind of an overhead pic of mine. Is this the "Hose" you are talking about? If so, pull that bolt out. The others are the same.
Old Nov 27, 2012 | 09:19 PM
justen920's Avatar
Just like that buddy, I will pull it out and find the size. How long are your braided hoses? I would love to upgrade to those. Thanks.
Old Nov 27, 2012 | 10:08 PM
Cool!!
I think one is 36" and the other 24" Or close to those numbers.
Old Nov 27, 2012 | 11:57 PM
Spooler's Avatar
Wish I had room to mount mine there. The darn APPS is in the way. I drilled and tapped my passenger side fram rail and mounted it there. I took a hammer and bent the bracket that was hanging over the rail down.
Old Dec 3, 2012 | 11:48 AM
justen920's Avatar
One more question, did you guys use teflon tape for all the connections? I am a little nervous about leaks.
Old Dec 3, 2012 | 04:37 PM
As you can see in my pic above, I only use it on the NPT threads. The hose fittings are flared and self seal as long as you don't strip them or over tighten them.
Old Dec 3, 2012 | 07:56 PM
Spooler's Avatar
No need for the teflon tap, you shouldn't have any issues.
Old Feb 19, 2013 | 01:20 PM
justen920's Avatar
One final question (I hope): How much extra oil does the extra filter hold? I am ready to purchase my oil and install this bad boy. Any tips on filling these up would be appreciated (fill filter half way, check oil and add if needed?). Sorry for the bonus question and thanks again for all your help.
Justen
Old Feb 19, 2013 | 01:53 PM
It holds a little over a quart. Just buy an extra gallon and keep it set aside for the next 3 changes.
Old Feb 19, 2013 | 03:34 PM
Spooler's Avatar
If you used an Amsoil filter they will tell you how much extra oil you will need. Find the filter on their site for that amount. I use the 110 filter which takes 2 extra quarts from what I remember.
jmccart
13
May 27, 2009 09:45 PM
jmccart
Dec 11, 2008 02:49 PM
kprc51
Dec 31, 2007 12:54 PM
rjm022
Feb 16, 2005 08:07 PM
Jmac
Nov 10, 2004 07:41 AM
