Am I Missing Something Here?
Old Feb 11, 2008 | 09:57 AM
J.T's Avatar
J.T
I just had all 6 injectors replaced with new factory one's because I had three go bad. Anyway, with the TDDL set on extreme Im getting about 14mpg(city). I put my truck back to stock tune and I'm getting 17mpg(city). Does this mean that something could be wrong with the downloader, or could it be something else. Any info is much appreciated, thank's.
Old Feb 11, 2008 | 10:02 AM
rip 112's Avatar
What do you run the triple dog on? A downloader can help you or hurt you when it comes to mpgs. What are egts, boost levels? The other thing is if you are running a higher hp level you could be draining the rail more than you know it, causing the mpg loss...do you still have the stock lift pump?
Old Feb 11, 2008 | 11:30 AM
J.T's Avatar
J.T
Thanks for the reply, I run the tripple dog on extreme. The weird thing is that before the injectors were installed I was getting around 18 or 19mpg with the tripple dog on extreme. I do still have the stock lift pump. Looking at Glacier Diesel lift pump or a Fass setup. This might not make any sense at all, but when I had the 3 bad injectors could they have kept the rail from draining with the tripple dog on extreme setting.
Old Feb 11, 2008 | 11:51 AM
trik396's Avatar
Generally anything that says "extreme" isn't going to yield better mpg's than stock. You are dumping more fuel, so how can you expect better economy?
Old Feb 11, 2008 | 06:24 PM
rip 112's Avatar
Seems like your lrail is starving and your lift pump has seen better days. Check your fuel pressure, check for codes, and fuel filter.
Old Feb 12, 2008 | 01:45 PM
J.T's Avatar
J.T
I guess I understand what you are saying. It was just a drastic change so I wasn't sure.
Old Feb 12, 2008 | 02:03 PM
J.T's Avatar
J.T
I ran a check for codes and it wasn't showing anything and I changed the fuel filter a few days ago. It was pretty dirty though. You are probably right, the lift pump has probably seen better days. It looks like the next thing on the mod list is a new lift pump. Thanks! Im still trying to learn about all this stuff.
Old Feb 12, 2008 | 02:07 PM
rip 112's Avatar
No Problem man! That's what we're here for....
Polarlys
Jan 26, 2011 10:05 AM
meathead
Nov 17, 2008 09:05 PM
johnr9q
17
Mar 30, 2004 08:58 AM
dodgeman01
Oct 2, 2003 01:29 PM
