Am I gonna blow something up?
Old Mar 31, 2012 | 04:44 PM
ubet's Avatar
I have a superchip cortex. I was tuning it awhile back from tow to performance, when the programmer flipped out and stopped working in the middle of the tune change. When I plug it in, it says programed for performance but feels like stock or towing when driving. The chip is getting sent back to be worked on. My question, is if I pull a horsetrailer with how ir is, will I blow something up or destroy the truck? The programmer says not to tow in performance. I do have an edge insight cya to read egts etc.
Thanks
Sent from my ADR6425LVW using Tapatalk
Old Mar 31, 2012 | 04:59 PM
jhenson's Avatar
As long as you have a way to monitor your engine you should be fine. Just don't stay heavy in the throttle for long periods of time.
Old Mar 31, 2012 | 05:11 PM
ubet's Avatar
What should I be monitoring? I currently monitor egts, engine temp, and boost. I don't hit the floor with the pedal, and drive real soft when I am pulling it usually doesn't get over 1100 egt
Old Mar 31, 2012 | 08:17 PM
Nate-03 D's Avatar
Will you blow something up? Ubet. lol just kidding.
From what you described, you should be more then fine. If your not getting over 1100*, you're more then fine. Drive that sucker all day with that setup and you'll be golden.
Old Apr 5, 2012 | 06:46 AM
michael/edge's Avatar
superchips is pretty famous for freaking out during programming. i would be watching my engine vitals while towing
VICIOUS FISHER
Mar 2, 2009 05:19 PM
BC847
Nov 4, 2008 09:51 PM
Copenhagenjunkie
Sep 10, 2007 02:30 PM
mkinla
18
Jan 9, 2006 10:26 PM
