Alignment tomorrow, post 2" spacers? Help? Death Wobble?
Old Mar 5, 2007 | 11:01 PM
jmccart's Avatar
Hello. I just want to double check something. I finally got my spacers in the front (2''). I am getting it aligned tomorrrow. I have experienced death wobble once, and that was enough. I had another thread going after I had the death wobble, and I was told by a friend from the North to adjust castor to the max (around 5 degrees). Do we all agree this is a good idea? I don't know squat about alignments.
Thanx.
Old Mar 6, 2007 | 01:03 AM
morkable's Avatar
Yes, castor to the max, make sure tire pressures are up too. You should be ok then
Kevin
Old Mar 6, 2007 | 07:10 AM
DirtEater's Avatar
I had one case of wobble on my 05 and it was due to an alignment problem. The toe was way off although it still tracked straight. I took it back to the shop and a more experienced tech spotted the toe issue. Never had a problem since then, but death wobble is no joke.
Old Mar 6, 2007 | 09:57 AM
jmccart's Avatar
OK guys, going in today, I am going to print this out & bring it. Castor to the max. Any more info or thoughts please keep it coming.
Thanx.
Old Mar 6, 2007 | 10:11 AM
Pooter's Avatar
Max caster!
After I installed my lift, went and had it aligned and the best they could do was 3*, so dont be discouraged if you dont get the ideal 4-5*...
Old Mar 6, 2007 | 11:59 PM
hilclmr2's Avatar
What kind of tires are you using? BFG's? I seem to remember a while back that a lot of DW happened with these tires, was a thread on the forum about it. Castor to the max and you should be good.
Old Mar 7, 2007 | 12:33 AM
jmccart's Avatar
Thanx guys. I had it done today. It was at 5.5 positive caster. I had told him to try to get it to 5. So he set it at 5. Hope I never hit DW again. Thanx for the tips & wish me luck.
725Gus
Mar 6, 2014 09:49 AM
benito
Jul 18, 2007 08:55 PM
Jezzhuntin
Apr 11, 2007 04:52 PM
jmccart
Feb 6, 2007 07:18 AM
Turbo Deeezle
Sep 24, 2004 10:42 PM
