Airdog wireing!!! HELP
Alright got everything mounted and the harness ran. Where in the heck do i hook the red wire with the 2 fuses into the fuse box at. I pulled the fuse on 33 i belive to get it to come on in the start postion.
I got to go to work in the morning so if u read please help!!!!
there should be two wires with ring connectors, hook them directly to the battery and connect the last wire to some form of switched 12V's. That will trigger the relay to make the pump run
Man I feel for ya! I would just get a ride to work if you can and deal with it tomorrow! Save yourself some frustration. Sans that do some searches and see if you can't find an install on here with pics of the harness and how it was connected. IIRC I did mine slightly different than the instructions said? So I'm no help there. Call down to pureflow and get some tech support.
Bump to the top anyway. Sorry
Maybe this will help? 53 ****** was helping me with some questions I had and I took a picture of the harness and he labeled it like this
Your harness look like this?
http://i255.photobucket.com/albums/h...0925080905.jpg
Heres the part that they put on the wireing harness that shouldnt of been when i called and asked them about it
deerezilla
Jan 28, 2009 09:47 AM
kdbvulcan
20
Dec 6, 2008 04:34 PM
JKM
Sep 7, 2005 01:21 PM
