airdog question
Old Mar 14, 2005 | 07:54 AM
jayrods600's Avatar
airdog question
Installed a airdog system this weekend. At idle the pump is louder but that is normal question is that it is making a gurgling/ slurping noise when im at a complete stop. could this be that there is still air in the lines? help please!
Old Mar 14, 2005 | 12:21 PM
Billy Ram's Avatar
When your tank is getting around 1/4 it gets air bubbles in the fuel. When you fill up it should get quieter . If it doesn't check your pickup line for a leak.
Old Mar 14, 2005 | 01:32 PM
jayrods600's Avatar
the tank is full and it make tha noise loud and clear. no leaks
Old Mar 14, 2005 | 01:52 PM
gatf4's Avatar
I would call Ekstram and ask them. My airdog is quiet enough that I can not hear it outside the vehicle or inside the vehicle under any conditions when the truck is running. I did mount mine in rubber bushings so that may make a difference. I can only hear mine if I crawl into my truck bed with the truck running. I do have a truck cap so it kind of resonates in there. Also, I used clamps on all the hose connections even though they are a clampless Push-loc design
Old Mar 14, 2005 | 03:31 PM
jayrods600's Avatar
it is the mounts i think I will re mount it and see what happens
01blackspeeper
Mar 23, 2012 04:52 PM
Tractor Truck
Jan 20, 2011 01:56 AM
kdbvulcan
20
Dec 6, 2008 04:34 PM
04RAM2500
Jan 7, 2008 08:48 PM
turbomike
Dec 15, 2007 10:21 PM
