Airdog with Cumming Exhaust Brake
Old Oct 18, 2008 | 11:45 AM
NDanecker's Avatar
Airdog with Cummins Exhaust Brake
I'm in the middle of installing an airdog pump and there is a clearance issue with the fitting/line that goes on the cp-3 pump. I have a cummins exhaust brake and the vacuum pump for the exhaust brake is directly above the cp3 pump. It is so close I can't install the supply line and fittings.
Is there a work around????? Can I connect to the other end that comes off the bottom of the oem filter housing????
Help!!!!
Thanks!
Old Oct 19, 2008 | 09:27 AM
NDanecker's Avatar
Found a thread on TDR that addresses this. Thanks anyways....
01blackspeeper
Mar 23, 2012 04:52 PM
Tractor Truck
Jan 20, 2011 01:56 AM
GlennRMK
May 12, 2009 04:03 PM
kdbvulcan
20
Dec 6, 2008 04:34 PM
