Air intake manifold question
I am looking for advice on which intake manifold to buy. I am trying to decide between the arch flow and cfm +. I almost bought a high ram from banks, but at the local diesel shop (keystone Diesel in PA ) they said the banks actually lowers hp and torque when they dynoed some trucks with it on. Because of the bulge and taper down effect of the high ram. I read some good results with the arch flow, and that the cfm+ is made of a composite metal which scares me. I haven't seen to much feedback on the cfm+ either. If anybody thinks I'm off base on banks ram speak up.
I want to put some more miles on my truck before I get the Smarty program. But I still want to play. Anybodys input would be appreciated.
I don't think there's an intake manifold that will increase hp over stock. Mostly the major benefits are the ports on them for boost gauges, water/meth, or nitrous. The only two I've seen that look good to me are the Arc-Flow (2 ports) and the Swanker (4 ports). The CFM+ is supposed to prevent heat soak but you can't drill and tap it. If you don't want to add anything like I mentioned above I would stay with the stocker.
Doesn't anybody have anything positive to say about the aftermarket intake manifolds? Are they that useless? Talked to some people today, they said you may only notice a difference on slightly modded trucks.
I ran twins at 70+psi boost at the track...plus running water/meth.....on the stock intake manifold....get a decent clutch... before you start replacing the silly stuff. I hope you entered the contest to win one...you'll need it. If you really want to get better intake performance remove the grid heaters in the summer and put in a spacer. ks
I have a week now on the CFM + and I would give it a thumbs up !!! Idles way better and throttle response is improved ,especially after warm up . There is a port you can drill but it is plastic remember ,if I use it I will epoxy a fitting in . Mileage is reading 2+ higher
we shall see over a few tanks . Nice piece and it comes with studs and all gaskets . Also got an ATS exhaust manifold just trying to find time to put it on
There is a bit of casting flah left inside nothing a piece of sandpaper and 10 minutes couldn't handle .
!!!There is a bit of casting flah left inside nothing a piece of sandpaper and 10 minutes couldn't handle .
You`ll be miles ahead of some crappy gimmick that only lets air into your wallet.
I got an ats arc flow on the way from xtreme diesel. According to many of you I'm wasting money, but if I don't like I'll sell it to recoop some $. I thought about the cfm + but the composite material kept me from buying it, plus the ats has ports for water/meth. I'll post back once I get on and drive some.
The big benefit from using a CFM is the fact it doesn't retain heat and it's flow rate can't be beat. If comparing it to a ATS then yes, it might seem cheap because of the ATS being made of metal.
I've had both on my truck and can say, there's NO significant benefit to having either. As was mentioned... one reason to not use a CFM is that it lacks any ports for injection.
Farmer, when you get the intake let me know. Since no one really talked about the banks(know its to late) but I like the banks. But like you said maybe a benifit cause of the mods who knows? I like to think it's if anything it's just a piece of mind?
I have the High Ram on mine, stock its nothing really, but with my mods i think its helps out pretty good. But it does look really cool when you open the hood, thats my biggest compliment i get. But overall not worth the money.
BA05'CTD
Jan 7, 2007 03:08 PM
Bobcat698
Sep 24, 2005 10:51 AM
